[mpich-discuss] MPI_Init problem
Jayesh Krishna jayesh at mcs.anl.gov
Fri May 8 09:05:03 CDT 2009
 Didn't passing in a dummy env block to CreateProcess() work for you (as
you mentioned in your prev emails) ?
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rod Cook
Sent: Monday, April 20, 2009 9:16 AM
Subject: [mpich-discuss] MPI_Init problem
I have a farming code where an MPI program spawns a number of jobs, these
jobs then run a sequence of other MPI applications which fail in MPI_Init.
I am using MPICH2 v1.08 under Windows XP. The MPI program (FARMER) spawns
two executables (JOB) using MPI_Comm_spawn. These executables (JOB) then
run (using CreateProcess) another MPI application (APP).  mpiexec is used
to start all the MPI executables.
APP crashes (times out) in it's call to MPI_Init with the following
message:
MPIDU_Sock_post_connect failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(83)........: channel initialization failed
MPID_Init(334).......: PMI_Init returned -1[0] PMI_ConnectToHost failed:
unable
to post a connect to Yellowtail yellowtail :1061, error: Unknown
error class, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Yellowtail yellowtail
                          on port 1061, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to                 on
port 1061,
 No connection could be made because the target machine actively refused
it. (er
rno 10061)
MPIDU_Sock_post_connect(1275): unable to connect to yellowtail on port
1061, No
connection could be made because the target machine actively refused it.
(errno
10061)
MPIDU_Sock_post_connect(1275): unable to connect to Yellowtail on port
1061, No
(errno
10061)
uPMI_ConnectToHost returning PMI_FAIL
[0] PMI_Init failed.
I think the crash is caused by MPI_Init in APP trying to synchronise with
MPI_Comm_spawn in FARMER. There is no need for this from the farming codes
point of view because APP is independent of both FARMER and JOB. The
farming works OK if I replace APP with a version that doesn't use MPI.
Thanks for your help,
Rod Cook
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090508/56035ffd/attachment-0001.htm>
