[mpich-discuss] MPI_Init problem
Rod Cook
rod at cookies.demon.co.uk
Fri May 8 08:57:31 CDT 2009
I have a farming code where an MPI program spawns a number of jobs, these jobs then run a sequence of other MPI applications which fail in MPI_Init. I am using MPICH2 v1.08 under Windows XP. The MPI program (FARMER) spawns two executables (JOB) using MPI_Comm_spawn. These executables (JOB) then run (using CreateProcess) another MPI application (APP). mpiexec is used to start all the MPI executables.
APP crashes (times out) in it's call to MPI_Init with the following message:
MPIDU_Sock_post_connect failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(83)........: channel initialization failed
MPID_Init(334).......: PMI_Init returned -1[0] PMI_ConnectToHost failed: unable
to post a connect to Yellowtail yellowtail :1061, error: Unknown
error class, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Yellowtail yellowtail
on port 1061, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to on port 1061,
No connection could be made because the target machine actively refused it. (er
rno 10061)
MPIDU_Sock_post_connect(1275): unable to connect to yellowtail on port 1061, No
connection could be made because the target machine actively refused it. (errno
10061)
MPIDU_Sock_post_connect(1275): unable to connect to Yellowtail on port 1061, No
10061)
uPMI_ConnectToHost returning PMI_FAIL
[0] PMI_Init failed.
I think the crash is caused by MPI_Init in APP trying to synchronise with MPI_Comm_spawn in FARMER. There is no need for this from the farming codes point of view because APP is independent of both FARMER and JOB. The farming works OK if I replace APP with a version that doesn't use MPI.
Thanks for your help,
Rod Cook
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090508/4ce28cfc/attachment.htm>
