[mpich-discuss] Build x86 version mpich2 on x86_64 Linux Boxfailed ...
Jayesh Krishna jayesh at mcs.anl.gov
Tue May 5 11:33:30 CDT 2009
Hi Seifer,
>>> I don't know if nemesis may conflict with smpd...
	There are some known issues
(https://trac.mcs.anl.gov/projects/mpich2/ticket/292) with multithreaded
MPI programs when you use smpd with nemesis (The bug/hang is not specific
to nemesis but shows up easily with nemesis). We will be fixing this bug
in the upcoming 1.1rc1 release. If you don't plan to use multithreaded MPI
programs, SMPD should work just fine with nemesis.
Jayesh
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
Sent: Tuesday, May 05, 2009 11:14 AM
To: Mpich Discuss
Subject: Re: [mpich-discuss] Build x86 version mpich2 on x86_64 Linux
Boxfailed ...
Hi Seifer
Seifer Lin wrote:
> Hi:
> For mpich2-1.0.8p1, it's OK!
Then think about sticking to mpich2-1.0.8p1, which is the right and wise
thing to do, and of rebuilding your programs with it.
I would suggest building with the ch3:nemesis communication channel,
instead of ch3:sock, which seems to be the default.
Some people reported problems with ch3:sock on current Linux kernels and
some types of Ethernet cards on this list and elsewhere.
However, I am not sure about nemesis in your case just because you seem to
prefer the smpd (--with-pm=smpd --with-pmi-=smpd).
I never used smpd.
The MPICH2 developers may clarify this point.
If you rebuild with nemesis, follow Rajeev's suggestion also:
delete the directory tree, untar again, and start fresh, to avoid old
object files on your way.
I hope this helps.
Gus Correa
Gustavo Correa
Lamont-Doherty Earth Observatory - Columbia University Palisades, NY,
10964-8000 - USA
> But for mpich2-1.0.3 (which I used), it's failed to build.
> regards,
> Seifer
> 2009/5/5 Rajeev Thakur <thakur at mcs.anl.gov
> <mailto:thakur at mcs.anl.gov>>
>     Delete the whole directory and try with a fresh untar of the tar
file.
>     Rajeev
>         *From:* mpich-discuss-bounces at mcs.anl.gov
>         <mailto:mpich-discuss-bounces at mcs.anl.gov>
>         <mailto:mpich-discuss-bounces at mcs.anl.gov>] *On Behalf Of
>         *Seifer Lin
>         *Sent:* Monday, May 04, 2009 8:53 PM
>         *To:* mpich-discuss at mcs.anl.gov
<mailto:mpich-discuss at mcs.anl.gov>
>         *Subject:* Re: [mpich-discuss] Build x86 version mpich2 on
>         Hi Gus:
>         Thank you for the advice.
>         But it still doesn't work. :(
>         regards,
>         Seifer
>         2009/5/4 Gus Correa <gus at ldeo.columbia.edu
>         <mailto:gus at ldeo.columbia.edu>>
>             Deji Akingunola wrote:
>                 On Sun, May 3, 2009 at 11:48 PM, Seifer Lin
>                 <seiferlin at gmail.com <mailto:seiferlin at gmail.com>>
wrote:
>                     Hi all:
>                     I use the following command to configure a x86
>                     version mpich2 on a x86_64
>                     Linux Box (Feroda Core 10 x86_64)
>                     ./configure CFLAGS="-m32 -fPIC" CXXFLAGS="-m32
>                     -fPIC" FFLAGS="-m32 -fPIC"
>                     LDFLAGS="-m32" --enable-sharedlibs=gcc --enable-mpe
>                     --with-pm=smpd
>                     --with-pmi-=smpd
>                     The configure step is OK.
>                     But when doing make, I get the following error...
>                     /usr/bin/ld: i386 architecture of input file
>                     `.tmp/ibsendf.o' is
>                     incompatible with i386:x86-64 output
>                     Does anyone know the way to build x86 version mpich2
>                     on x64 Linux Box ?
>                     Thanks.
>                 On Fedora 10 you have 2 options involving building rpms
>                 (I'm assuming
>                 you know how to build rpms). Grab the MPICH2 rpm spec
>                 file for Fedora
>                 10 from
>                 http://cvs.fedoraproject.org/viewvc/rpms/mpich2/F-10/,
>                 modify
>                 the configure options to suit your needs, and then
>                 rebuild the source
>                 rpm.
>                 i. Install mock and then run; 'mock  -r  fedora-10-i386
>                 --resultdir=./my-results  /path/to/your.mpich2.src.rpm'
>                 ii. Run 'setarch i386 rpmbuild --rebuild
>                 (Assuming you have all the right 32bit buildchain
> installed)
>                 Option (i) is more likely to get the job done for you
>                 easily.
>                 Cheers,
>                 Deji
>                     regards,
>                     Seifer Lin
>             Hi Seifer
>             Two guesses.
>             Have you tried a "make distclean" before "configure"?
>             You may have leftover x86_64 object files from previous
builds
>             hanging around.
>             You may need also F90FLAGS="-m32 -fPIC".
>             I hope this helps,
>             Gus Correa
>             Gustavo Correa
>             Palisades, NY, 10964-8000 - USA
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090505/90a5ad0e/attachment.htm>
