[mpich-discuss] How to build libmpe.so ?
Anthony Chan
chan at mcs.anl.gov
Mon May 4 20:54:49 CDT 2009
Seifer,
----- "Seifer Lin" <seiferlin at gmail.com> wrote:
> Now I want to port this DLL to Linux as the .so file.
> I try to build mpich with
> ./configure --enable-sharedlibs=gcc --with-pm=smpd --with-pmi=smpd
> but I only find libmpich.so and libmpe.a.
> How to build mpe as the .so (libmpe.so) ?
MPE currently does not have shared library support yet.
If you really need libmpe.so, you can build MPE as a standalone
package for MPICH2 with CFLAGS set to -fPIC. You can then
use the .o files (from libmpe.a) and build your own libmpe.so.
To build typical MPI executable, you can mix libmpich.so and libmpe.a.
> Without libmpe.so, I got the error when building my .so file.
What .so file you are building that needs libmpe.so ?
A.Chan
> /usr/bin/ld: ./mpich2-x64/src/mpe2/lib/libmpe.a(mpe_log.o):
> relocation
> R_X86_64_32 against `a local symbol' can not be used when making a
> shared
> object; recompile with -fPIC
> ./mpich2-x64/src/mpe2/lib/libmpe.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> regards,
> Seifer Lin
