[mpich-discuss] Message Protocols
Marcelo Tomim
marcelot at ece.ubc.ca
Mon May 4 11:57:10 CDT 2009
Hello Rajeev,
I am using the techniques suggested in
Kielmann, T., Bal, H. E., & Verstoep, K. (2000). Fast measurement of
LogP parameters for message passing platforms. of Lecture Notes in
Computer Science, 1800, 1176-1183.
Below is the code excerpt for measuring the sending overhead:
for (k = 0; k < M; k++){
if (rank == 0){
// This is the measuring process
start = MPI_Wtime();
MPI_Send(buffer, size, MPI_BYTE, 1, k, world);
stop_os = MPI_Wtime();
time_os += stop_os - start; // Take the time for a
single send
time_os /= M; //! Take the time for a
single send
else{
MPI_Recv(buffer, size, MPI_BYTE, 0, k, world, &status);
Now the receiving overhead timing:
if (rank == 0){
MPI_Send(buffer, 0, MPI_BYTE, 1, k, world);
wait_delta(delta_t);
start_or = MPI_Wtime();
MPI_Recv(buffer, size, MPI_BYTE, 1, k, world, &status);
stop_or = MPI_Wtime();
time_or += stop_or - start_or;
else{
MPI_Recv(buffer, 0, MPI_BYTE, 0, k, world, &status);
MPI_Send(buffer, size, MPI_BYTE, 0, k, world);
While the sending overhead timing is quite intuitive, the receiving
overhead demands a little more explanation. The main difference here is
the presence of the controlled waiting function wait_delta. In this
case, making delta_t big enough so it is greater than the round trip
time for messages of size m will guarantee that there won't be any idle
time in the MPI_Recv and the time measured is the true receiving
overhead. The round trip time is measured before this routine is called.
I hope it makes sense.
Marcelo Tomim.
Rajeev Thakur wrote:
> How are you measuring the overhead for receiving versus sending?
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Marcelo Tomim
>> Sent: Wednesday, April 29, 2009 7:31 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] Message Protocols
>> Hello MPI users,
>> I have the results of some point-to-point benchmarks on
>> MPICH2 library
>> and I have been having a hard time to interpret them.
>> The test is based on paired Send and Recv routines, similar
>> to ping-pong
>> tests. One specific detail I have been wondering about is the
>> fact that
>> for large messages (larger than 128kB, i.e., rendezvous
>> protocol), the
>> overhead for sending is much smaller that the overhead for
>> receiving. I
>> was expecting them to be close to one another, based on the fact that
>> the receiver has to acknowledge to the sender that the
>> message has been
>> successfully received. There must be a flaw in this
>> reasoning, but I don
>> not where it is.
>> Could any one help me with that or indicate me a document which
>> explains, in detail, all the message protocols (short, eager and
>> rendezvous) employed in the MPICH2 implementation?
>> Thank you all very much for your attention.
>> Regards,
>> Marcelo Tomim.
