[mpich-discuss] MPICH on intel x86_64 core2 quad + fedora 10
Dhiraj
ballack.mamba at gmail.com
Mon Mar 30 12:36:58 CDT 2009
Dear Sir,
I tried to reload the mpich2 again on the machine and followed the procedure
as per the installation guide.
Also, as per the earlier suggestion, I did the ./configure with the option
--with-device=ch3:nemesis
After exporting the PATH, I could successfully run,
which mpd,
which mpicc
which mpiexec
which mpirun
As per the further guidelines, I have created .mpd.conf file with a
secretword.
But now, I get following error when I do mpdtrace:
mpdtrace (mpdtrace 57): got eof on console
Possibly, I have committed some serious mistake somewhere. Please help me
regarding this.
Sincerely,
Dhiraj.
2009/2/21 Rajeev Thakur <thakur at mcs.anl.gov>
> Does the cpi example in the examples directory run? If you do "make
> testing" in the top-level mpich2 directory it will run the entire test suite
> in test/mpi (takes an hour). If these programs run, the problem is likely in
> your application or the way it is compiled or something like that.
> Rajeev
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Dhiraj
> *Sent:* Saturday, February 21, 2009 4:47 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] MPICH on intel x86_64 core2 quad + fedora
> 10
> Dear Rajeev,
> I followed steps from installation guide and used MPICH2 with mentioned
> configure option.
> If I do I get following outputs,
> # mpd & --- starts mpd
> # mpdtrace
> COMB2 (hostname of my machine)
> # mpdallexit
> exits mpd
> I have compiled the parallel code and run when mpd is on using following
> command
> # mpirun -n 4 ./BURN
> (BURN is executable file).... The program execution hangs and I have to do
> ``ctrl + c''
> I get following message,
> ^CTraceback (most recent call last):
> File "<stdin>", line 811, in <module>
> File "<stdin>", line 374, in mpdboot
> File "<string>", line 1, in connect_ex
> KeyboardInterrupt
> I am having no clue about what is happening. Please help me in this regard.
> Yours,
> Dhiraj.
> 2009/2/20 Rajeev Thakur <thakur at mcs.anl.gov>
>> You can just follow the instructions in the MPICH2 installation guide.
>> You can use MPICH2 1.0.8 and configure with the option
>> --with-device=ch3:nemesis .
>> Rajeev
>> *Sent:* Thursday, February 19, 2009 11:11 PM
>> *Subject:* [mpich-discuss] MPICH on intel x86_64 core2 quad + fedora 10
>> Dear Sir,
>> I want to install MPICH library on intel x86_64 core2 quad + fedora 10
>> (OS).
>> I seek your help regarding an installation guide and ``hello_world''
>> program execution guide
>> for this shared memory multi-core machine.
>> With warm regards,
>> Dhiraj Patil
>> IISc, Bangalore.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090330/07a76118/attachment.htm>
