[mpich-discuss] HP-XC 3000 cluster issues
    Gauri Kulkarni
    gaurivk at gmail.com
    Tue Mar 24 06:32:21 CDT 2009
You are right, that's what I was writing just now, I am just out of my
mind..
Sorry..
Gauri.
On Tue, Mar 24, 2009 at 4:51 PM, Gauri Kulkarni <gaurivk at gmail.com> wrote:
> I apologize for bringing this up again and again (meaning, not realizing
> the errors when they occured) :(
> Just a background recap: I am trying to configure MPICH2 with SLURM on our
> HP-XC cluster. I have used 'configure' with following options:
> /configure --prefix=/data1/visitor/cgaurik/mympi/ --with-pmi=slurm
> --with-slurm=/opt/hptc/slurm  --with-pm=no --enable-sharedlibs=gcc
> After this, I could run mpiexec with srun of SLURM but it had failed to run
> because mpd could not be started on the assigned nodes. But here, I was told
> that when MPICH2 is configured correctly with SLURM, I should not use
> mpiexec, but just use "srun" from SLURM. During the March 5th trial (see the
> email below), I had used the command "bsub -n16 srun ./helloworld.mpich2"
> and I have given the output in the email. I had thought at that time that it
> was the correct output. But, if you see the ranks of the processes, they are
> incorrect.
> Our cluster has 8 procs per node and a total of 16 nodes. So the output
> should be:
> Hello world! I'm 0 of 1 on n4
> Hello world! I'm 1 of 1 on n4
> Hello world! I'm 2 of 1 on n4
> Hello world! I'm 3 of 1 on n4
> Hello world! I'm 4 of 1 on n4
> Hello world! I'm 5 of 1 on n4
> Hello world! I'm 6 of 1 on n4
> Hello world! I'm 7 of 1 on n4
> Hello world! I'm 0 of 1 on n5
> Hello world! I'm 1 of 1 on n5
> Hello world! I'm 2 of 1 on n5
> Hello world! I'm 3 of 1 on n5
> Hello world! I'm 4 of 1 on n5
> Hello world! I'm 5 of 1 on n5
> Hello world! I'm 6 of 1 on n5
> Hello world! I'm 7 of 1 on n5
> I feel like a complete idiot for not catching this earlier and thinking my
> wrong output (in the email below) was correct one. So basically, I still
> have no idea what the heck is wrong with my configuring MPICH2 with SLURM.
> PLEASE.. help.
> Gauri.
> On Thu, Mar 5, 2009 at 7:53 PM, Gauri Kulkarni <gaurivk at gmail.com> wrote:
>> Dave,
>> The output of "bsub -n 16 srun ./helloworld.mpich2" is as follows:
>> (exactly as it should be)
>> Your job looked like:
>> # LSBATCH: User input
>> Successfully completed.
>> Resource usage summary:
>>     CPU time   :      0.21 sec.
>>     Max Memory :        12 MB
>>     Max Swap   :       178 MB
>> The output (if any) follows:
>> Of course, using the same command - only with mpirun -srun
>> ./helloworld.mpich2 - still gives me the error that no mpd is running on the
>> node on which the job was assigned.
>> Does this mean, I do not need to use mpirun when MPICH2 is configured with
>> SLURM? What about the softwares that make specific call to mpirun or
>> mpiexec?
>> Gauri.
>> On Thu, Mar 5, 2009 at 7:27 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
>>> Gauri,
>>> Unless I'm misunderstanding your situation, I don't believe that you
>>> should be trying to run MPD.  MPICH2 should work directly with SLURM (at
>>> least srun) when configured with --with-pmi=slurm.
>>> Can you try something like this instead:
>>> % bsub -n 16 srun ./helloworld.mpich2
>>> -Dave
>>> On Mar 5, 2009, at 1:58 AM, Gauri Kulkarni wrote:
>>>  Thanks Dave! This worked. At least I can use bsub and mpirun is
>>>> accepting the srun option. Of course, the job is failing still. I issued the
>>>> following command:
>>>> bsub -n15 -o helloworld.mympi.%J.out mpirun -srun ./helloworld.mpich2
>>>> When I checked where the job was running, it showed me two nodes
>>>> assigned. Our cluster is 16 nodes with 8 processrors per node, so this is
>>>> exactly what I wanted. But the problem is, no mpd is running on those
>>>> assigned nodes. Hence the program cannot run. I cannot start mpd on those
>>>> nodes because users have no ssh/rsh access to the nodes other than head node
>>>> and the last node. So I started mpd on the headnode (n0) and last node (n53)
>>>> and issued above command with additional option:
>>>> bsub -n15 -o helloworld.mympi.%J.out -ext "SLURM[nodelist=n0,n53]"
>>>> Now the job just remains in pending state instead of running. I cannot
>>>> do anything with it but to kill it.
>>>> Since only root can access all the nodes, only root can start mpds on
>>>> all of them. Can root start mpd once, say using mpdboot -n 16 -f
>>>> <mpd.hosts>, and then let it be? Or do I need to terminate mpd once the job
>>>> is done? Is there a way for users to start mpd on the node as it gets
>>>> assigned through bsub?
>>>> Thank you for your replies so far, they are really helping.
>>>> Gauri.
>>>> On Wed, Mar 4, 2009 at 10:27 PM, Dave Goodell <goodell at mcs.anl.gov>
>>>> wrote:
>>>> Gauri,
>>>> Do you know where your slurm headers and libraries are located?  You can
>>>> specify a root for the slurm installation via the
>>>> "--with-slurm=/path/to/slurm/prefix" option to configure.
>>>> For example, if you have the following files:
>>>> /foo/bar/baz/lib/libpmi.a
>>>> /foo/bar/baz/include/slurm/pmi.h
>>>> Then pass "--with-slurm=/foo/bar/baz" to configure.  If "/foo/bar/baz"
>>>> is "/usr" or "/" then this should have worked without the "--with-slurm"
>>>> option.  Almost any other prefix will require this option.
>>>> If you have a nonstandard layout for your slurm installation there are
>>>> other configure arguments you can pass to make everything work too.  But
>>>> let's hold off on discussing those until we know that you need it.
>>>> -Dave
>>>> On Mar 4, 2009, at 6:40 AM, Gauri Kulkarni wrote:
>>>> Ok, I have tried to recompile MPICH2 with following options. I cannot
>>>> recompile the 'global version', so I have tried to install it in my home dir
>>>> and would update the PATH accordingly. But compiling is failing at the
>>>> 'configure' step with following error:
>>>> command: ./configure --prefix=/data1/visitor/cgaurik/mympi/
>>>> --with-pmi=slurm --with-pm=no
>>>> End part of the output:
>>>> RUNNING CONFIGURE FOR THE SLURM PMI
>>>> checking for make... make
>>>> checking whether clock skew breaks make... no
>>>> checking whether make supports include... yes
>>>> checking whether make allows comments in actions... yes
>>>> checking for virtual path format... VPATH
>>>> checking whether make sets CFLAGS... yes
>>>> checking for gcc... gcc
>>>> checking for C compiler default output file name... a.out
>>>> checking whether the C compiler works... yes
>>>> checking whether we are cross compiling... no
>>>> checking for suffix of executables...
>>>> checking for suffix of object files... o
>>>> checking whether we are using the GNU C compiler... yes
>>>> checking whether gcc accepts -g... yes
>>>> checking for gcc option to accept ANSI C... none needed
>>>> checking how to run the C preprocessor... gcc -E
>>>> checking for slurm/pmi.h... no
>>>> configure: error: could not find slurm/pmi.h.  Configure aborted
>>>> configure: error: Configure of src/pmi/slurm failed!
>>>> Gauri.
>>>> > > > Message: 4
>>>> > > > Date: Mon, 23 Feb 2009 23:38:06 -0600
>>>> > > > From: "Rajeev Thakur" <thakur at mcs.anl.gov>
>>>> > > > Subject: Re: [mpich-discuss] HP-XC 3000 cluster issues
>>>> > > > To: <mpich-discuss at mcs.anl.gov>
>>>> > > > Message-ID: <72376B2D10EC43F9A0A433C960F951B6 at thakurlaptop>
>>>> > > > Content-Type: text/plain; charset="us-ascii"
>>>> > > > To run MPICH2 with SLURM, configure with the options
>>>> > > > "--with-pmi=slurm
>>>> > > > --with-pm=no" as described in the MPICH2 README file. Also see
>>>> > the
>>>> > > > instructions on how to run MPICH2 with SLURM at
>>>> > > > https://computing.llnl.gov/linux/slurm/quickstart.html .
>>>> > > > Rajeev
>>>> > > >  _____
>>>> > > > From: mpich-discuss-bounces at mcs.anl.gov
>>>> > > > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gauri
>>>> > > > Kulkarni
>>>> > > > Sent: Monday, February 23, 2009 11:19 PM
>>>> > > > To: mpich-discuss at mcs.anl.gov
>>>> > > > Subject: [mpich-discuss] HP-XC 3000 cluster issues
>>>> > > > Hi,
>>>> > > > I am a newbie to the MPI in general. Currently in our institute,
>>>> > we
>>>> > > > have a
>>>> > > > cluster of 16nodes-8processors. It is an HP-XC 3000 cluster which
>>>> > > > basically
>>>> > > > means, it's quite proprietary. It has its own MPI implementation
>>>> > > > HP-MPI -
>>>> > > > in which, the parallelization is managed by SLURM (Simple Linux
>>>> > > > Utility for
>>>> > > > Resource Management). There is also a batch job scheduler - LSF
>>>> > (Load
>>>> > > > Sharing Facility) which works in tandem with SLURM to parallelize
>>>> > the
>>>> > > > batch
>>>> > > > jobs. We have installed both MPICH and MPICH2 and are testing it,
>>>> > but
>>>> > > > we are
>>>> > > > running into compatibility issues. For a simple helloworld.c
>>>> > program:
>>>> > > > 1. For HPMPI: Compiled with mpicc of this implemetation and
>>>> > executed
>>>> > > > with
>>>> > > > its mpirun: mpirun -np 4 helloworld works correctly. For batch
>>>> > > > scheduling,
>>>> > > > we need to isse "bsub -n4 [other options] mpirun -srun helloworld"
>>>> > and
>>>> > > > it
>>>> > > > runs fine too. "srun" is SLURM utility that parallelizes the
>>>> > jobs.
>>>> > > > 2. For MPICH and mPICH2: Again, compiled with mpicc of these
>>>> > > > respective
>>>> > > > implemetations and executed with their own mpirun:
>>>> > > >    i) mpirun -np 4 helloword : Works.
>>>> > > >   ii) mpirun -np 15 helloworld: The parallelization is limited to
>>>> > just
>>>> > > > a
>>>> > > > single node - that is 8 processes run first on 8 processors of a
>>>> > > > single node
>>>> > > > and then remaining ones.
>>>> > > >  iii) bsub -n4 [options] mpirun -srun hellowrold: Job terminated.
>>>> > > > srun
>>>> > > > option not recognized.
>>>> > > >   iv) bsub [options] mpirun -np 4 helloworld: Works
>>>> > > >   V) bsub [options] mpirun -np 15 helloworld: (Same as iii)
>>>> > > > Anybody aware of HP cluster issues with MPICH? Am I
>>>> > misinterpreting?
>>>> > > > Any
>>>> > > > help is appreciated.
>>>> > > > Gauri.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090324/6b381abb/attachment-0001.htm>
