[mpich-discuss] HP-XC 3000 cluster issues
    Gauri Kulkarni
    gaurivk at gmail.com
    Tue Mar 24 06:21:09 CDT 2009
I apologize for bringing this up again and again (meaning, not realizing the
errors when they occured) :(
Just a background recap: I am trying to configure MPICH2 with SLURM on our
HP-XC cluster. I have used 'configure' with following options:
/configure --prefix=/data1/visitor/cgaurik/mympi/ --with-pmi=slurm
--with-slurm=/opt/hptc/slurm  --with-pm=no --enable-sharedlibs=gcc
After this, I could run mpiexec with srun of SLURM but it had failed to run
because mpd could not be started on the assigned nodes. But here, I was told
that when MPICH2 is configured correctly with SLURM, I should not use
mpiexec, but just use "srun" from SLURM. During the March 5th trial (see the
email below), I had used the command "bsub -n16 srun ./helloworld.mpich2"
and I have given the output in the email. I had thought at that time that it
was the correct output. But, if you see the ranks of the processes, they are
incorrect.
Our cluster has 8 procs per node and a total of 16 nodes. So the output
should be:
Hello world! I'm 0 of 1 on n4
Hello world! I'm 1 of 1 on n4
Hello world! I'm 2 of 1 on n4
Hello world! I'm 3 of 1 on n4
Hello world! I'm 4 of 1 on n4
Hello world! I'm 5 of 1 on n4
Hello world! I'm 6 of 1 on n4
Hello world! I'm 7 of 1 on n4
Hello world! I'm 0 of 1 on n5
Hello world! I'm 1 of 1 on n5
Hello world! I'm 2 of 1 on n5
Hello world! I'm 3 of 1 on n5
Hello world! I'm 4 of 1 on n5
Hello world! I'm 5 of 1 on n5
Hello world! I'm 6 of 1 on n5
Hello world! I'm 7 of 1 on n5
I feel like a complete idiot for not catching this earlier and thinking my
wrong output (in the email below) was correct one. So basically, I still
have no idea what the heck is wrong with my configuring MPICH2 with SLURM.
PLEASE.. help.
Gauri.
On Thu, Mar 5, 2009 at 7:53 PM, Gauri Kulkarni <gaurivk at gmail.com> wrote:
> Dave,
> The output of "bsub -n 16 srun ./helloworld.mpich2" is as follows: (exactly
> as it should be)
> Your job looked like:
> # LSBATCH: User input
> Successfully completed.
> Resource usage summary:
>     CPU time   :      0.21 sec.
>     Max Memory :        12 MB
>     Max Swap   :       178 MB
> The output (if any) follows:
> Of course, using the same command - only with mpirun -srun
> ./helloworld.mpich2 - still gives me the error that no mpd is running on the
> node on which the job was assigned.
> Does this mean, I do not need to use mpirun when MPICH2 is configured with
> SLURM? What about the softwares that make specific call to mpirun or
> mpiexec?
> Gauri.
> On Thu, Mar 5, 2009 at 7:27 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
>> Gauri,
>> Unless I'm misunderstanding your situation, I don't believe that you
>> should be trying to run MPD.  MPICH2 should work directly with SLURM (at
>> least srun) when configured with --with-pmi=slurm.
>> Can you try something like this instead:
>> % bsub -n 16 srun ./helloworld.mpich2
>> -Dave
>> On Mar 5, 2009, at 1:58 AM, Gauri Kulkarni wrote:
>>  Thanks Dave! This worked. At least I can use bsub and mpirun is accepting
>>> the srun option. Of course, the job is failing still. I issued the following
>>> command:
>>> bsub -n15 -o helloworld.mympi.%J.out mpirun -srun ./helloworld.mpich2
>>> When I checked where the job was running, it showed me two nodes
>>> assigned. Our cluster is 16 nodes with 8 processrors per node, so this is
>>> exactly what I wanted. But the problem is, no mpd is running on those
>>> assigned nodes. Hence the program cannot run. I cannot start mpd on those
>>> nodes because users have no ssh/rsh access to the nodes other than head node
>>> and the last node. So I started mpd on the headnode (n0) and last node (n53)
>>> and issued above command with additional option:
>>> bsub -n15 -o helloworld.mympi.%J.out -ext "SLURM[nodelist=n0,n53]" mpirun
>>> Now the job just remains in pending state instead of running. I cannot do
>>> anything with it but to kill it.
>>> Since only root can access all the nodes, only root can start mpds on all
>>> of them. Can root start mpd once, say using mpdboot -n 16 -f <mpd.hosts>,
>>> and then let it be? Or do I need to terminate mpd once the job is done? Is
>>> there a way for users to start mpd on the node as it gets assigned through
>>> bsub?
>>> Thank you for your replies so far, they are really helping.
>>> Gauri.
>>> On Wed, Mar 4, 2009 at 10:27 PM, Dave Goodell <goodell at mcs.anl.gov>
>>> wrote:
>>> Gauri,
>>> Do you know where your slurm headers and libraries are located?  You can
>>> specify a root for the slurm installation via the
>>> "--with-slurm=/path/to/slurm/prefix" option to configure.
>>> For example, if you have the following files:
>>> /foo/bar/baz/lib/libpmi.a
>>> /foo/bar/baz/include/slurm/pmi.h
>>> Then pass "--with-slurm=/foo/bar/baz" to configure.  If "/foo/bar/baz" is
>>> "/usr" or "/" then this should have worked without the "--with-slurm"
>>> option.  Almost any other prefix will require this option.
>>> If you have a nonstandard layout for your slurm installation there are
>>> other configure arguments you can pass to make everything work too.  But
>>> let's hold off on discussing those until we know that you need it.
>>> -Dave
>>> On Mar 4, 2009, at 6:40 AM, Gauri Kulkarni wrote:
>>> Ok, I have tried to recompile MPICH2 with following options. I cannot
>>> recompile the 'global version', so I have tried to install it in my home dir
>>> and would update the PATH accordingly. But compiling is failing at the
>>> 'configure' step with following error:
>>> command: ./configure --prefix=/data1/visitor/cgaurik/mympi/
>>> --with-pmi=slurm --with-pm=no
>>> End part of the output:
>>> RUNNING CONFIGURE FOR THE SLURM PMI
>>> checking for make... make
>>> checking whether clock skew breaks make... no
>>> checking whether make supports include... yes
>>> checking whether make allows comments in actions... yes
>>> checking for virtual path format... VPATH
>>> checking whether make sets CFLAGS... yes
>>> checking for gcc... gcc
>>> checking for C compiler default output file name... a.out
>>> checking whether the C compiler works... yes
>>> checking whether we are cross compiling... no
>>> checking for suffix of executables...
>>> checking for suffix of object files... o
>>> checking whether we are using the GNU C compiler... yes
>>> checking whether gcc accepts -g... yes
>>> checking for gcc option to accept ANSI C... none needed
>>> checking how to run the C preprocessor... gcc -E
>>> checking for slurm/pmi.h... no
>>> configure: error: could not find slurm/pmi.h.  Configure aborted
>>> configure: error: Configure of src/pmi/slurm failed!
>>> Gauri.
>>> > > > Message: 4
>>> > > > Date: Mon, 23 Feb 2009 23:38:06 -0600
>>> > > > From: "Rajeev Thakur" <thakur at mcs.anl.gov>
>>> > > > Subject: Re: [mpich-discuss] HP-XC 3000 cluster issues
>>> > > > To: <mpich-discuss at mcs.anl.gov>
>>> > > > Message-ID: <72376B2D10EC43F9A0A433C960F951B6 at thakurlaptop>
>>> > > > Content-Type: text/plain; charset="us-ascii"
>>> > > > To run MPICH2 with SLURM, configure with the options
>>> > > > "--with-pmi=slurm
>>> > > > --with-pm=no" as described in the MPICH2 README file. Also see
>>> > the
>>> > > > instructions on how to run MPICH2 with SLURM at
>>> > > > https://computing.llnl.gov/linux/slurm/quickstart.html .
>>> > > > Rajeev
>>> > > >  _____
>>> > > > From: mpich-discuss-bounces at mcs.anl.gov
>>> > > > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gauri
>>> > > > Kulkarni
>>> > > > Sent: Monday, February 23, 2009 11:19 PM
>>> > > > To: mpich-discuss at mcs.anl.gov
>>> > > > Subject: [mpich-discuss] HP-XC 3000 cluster issues
>>> > > > Hi,
>>> > > > I am a newbie to the MPI in general. Currently in our institute,
>>> > we
>>> > > > have a
>>> > > > cluster of 16nodes-8processors. It is an HP-XC 3000 cluster which
>>> > > > basically
>>> > > > means, it's quite proprietary. It has its own MPI implementation
>>> > > > HP-MPI -
>>> > > > in which, the parallelization is managed by SLURM (Simple Linux
>>> > > > Utility for
>>> > > > Resource Management). There is also a batch job scheduler - LSF
>>> > (Load
>>> > > > Sharing Facility) which works in tandem with SLURM to parallelize
>>> > the
>>> > > > batch
>>> > > > jobs. We have installed both MPICH and MPICH2 and are testing it,
>>> > but
>>> > > > we are
>>> > > > running into compatibility issues. For a simple helloworld.c
>>> > program:
>>> > > > 1. For HPMPI: Compiled with mpicc of this implemetation and
>>> > executed
>>> > > > with
>>> > > > its mpirun: mpirun -np 4 helloworld works correctly. For batch
>>> > > > scheduling,
>>> > > > we need to isse "bsub -n4 [other options] mpirun -srun helloworld"
>>> > and
>>> > > > it
>>> > > > runs fine too. "srun" is SLURM utility that parallelizes the
>>> > jobs.
>>> > > > 2. For MPICH and mPICH2: Again, compiled with mpicc of these
>>> > > > respective
>>> > > > implemetations and executed with their own mpirun:
>>> > > >    i) mpirun -np 4 helloword : Works.
>>> > > >   ii) mpirun -np 15 helloworld: The parallelization is limited to
>>> > just
>>> > > > a
>>> > > > single node - that is 8 processes run first on 8 processors of a
>>> > > > single node
>>> > > > and then remaining ones.
>>> > > >  iii) bsub -n4 [options] mpirun -srun hellowrold: Job terminated.
>>> > > > srun
>>> > > > option not recognized.
>>> > > >   iv) bsub [options] mpirun -np 4 helloworld: Works
>>> > > >   V) bsub [options] mpirun -np 15 helloworld: (Same as iii)
>>> > > > Anybody aware of HP cluster issues with MPICH? Am I
>>> > misinterpreting?
>>> > > > Any
>>> > > > help is appreciated.
>>> > > > Gauri.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090324/6dd18927/attachment.htm>
