[mpich-discuss] Problem using Mpich2 on Vista machines
    Larry Adams
    ladams at platform.com
    Wed Jun 24 14:36:53 CDT 2009
Jack,
Try the firewall first, you have to unblock the smpd service port.
Beyond that, you have to verify that smpd service is installed,  and if
it's another host, you will either have to register a pass phrase, or
your account on the execution node to be able to continue.  If your
password ever changes, you have to re-perform this step.
Larry Adams
Senior Systems Engineer
Platform Computing
Tele: (586) 510-0007
Cell: (586) 899-1138
Skype: TheWitness
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Fairchild, Jack
Sent: Wednesday, June 24, 2009 3:26 PM
Subject: [mpich-discuss] Problem using Mpich2 on Vista machines
I've debugged as far as I can:
Invoking the command: mpiexec -validate -host myhost  returns:
Aborting: connection to smpd rejected
Invoking mpiexec -file myfile  returns:
Aborting: unable to connect to myhost
Some background.
All computers are running Vista Ultimate.  The computers are connected
by a 100mbs LAN.  A few months ago, I set up 4 machines for this use.
They all still connect without issue.
At this point I need to add some more, but am getting these errors.  All
machines have smpd version 1.0.8.  I am an administrator on all
machines, and installed Mpich2 as the administrator.  UAC was turned off
and remains off, all known firewalls are also off.  A path variable to
the bin directory  was added.
I ran smpd -d and all of the parameters match those of the working
computers.
What am I missing here?  I appreciate your valuable time.
Jack Fairchild
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/c1eb8493/attachment.htm>
