[mpich-discuss] CPI test fails under Fedora 10
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Jun 24 10:49:18 CDT 2009
Just as an experiment, can you try configuring mpich2 with
--with-device=ch3:sock, run  make clean, make, and make install, and see
if that makes any difference?
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
peter_raeth at juno.com
Sent: Wednesday, June 24, 2009 8:13 AM
Subject: Re: [mpich-discuss] CPI test fails under Fedora 10
Can you also test with installing the MPICH2 rpms ('just run "yum
install mpich2*"), after you've removed (or moved aside) your
previously self-built copy?
Deji
The yum install went well, as did the single-machine tests described in
the installer's guide.
Could not find test_barriers* in the file system.
Built the attached pi code. The build went well but would not execute:
[Guest at Hack03 Download]$ ls
pi.cxx
[Guest at Hack03 Download]$ mpicxx pi.cxx -o pi
[Guest at Hack03 Download]$ ./pi
Illegal instruction
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/b2f1e4c5/attachment-0001.htm>
