[mpich-discuss] CPI test fails under Fedora 10
peter_raeth at juno.com
Wed Jun 24 08:13:19 CDT 2009
Can you also test with installing the MPICH2 rpms ('just run "yum
install mpich2*"), after you've removed (or moved aside) your
previously self-built copy?
Deji
The yum install went well, as did the single-machine tests described in the installer's guide.
Could not find test_barriers* in the file system.
Built the attached pi code. The build went well but would not execute:
[Guest at Hack03 Download]$ ls
pi.cxx
[Guest at Hack03 Download]$ mpicxx pi.cxx -o pi
[Guest at Hack03 Download]$ ./pi
Illegal instruction
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/c4f9cfab/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/c4f9cfab/attachment.diff>
