[mpich-discuss] CPI test fails under Fedora 10
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Jun 23 17:01:14 CDT 2009
It might be easier to run "make check" from the src/openpa/
directory.  That should run all the openpa tests.
-Dave
On Jun 23, 2009, at 4:31 PM, Darius Buntinas wrote:
> Hmm, still not sure why you can't compile test_barriers.  Let's try
> this:
> cd /home/Guest/Download/mpich2-1.1/src/openpa
> ls
> ./configure
> make
> cd test
> ls
> make test_barriers
> ./test_barriers
> Thanks,
> -d
> On 06/23/2009 03:45 PM, peter_raeth at juno.com wrote:
>> You shouldn't need to reinstall F10, just "yum install glibc-devel"
>> should do it if it's not installed.  "rpm -V glibc-devel" will verify
>> that all of the files in the package are installed correctly.
>> When you rebuild mpich2, please send us the c.txt and m.txt files
>> (described on page 3 of the installer's guide).
>> Thanks,
>> -d
>> Wanted to be sure I actually installed everything from F10. Finished
>> that process and reinstalled source mpich2.
>> Attached is the console output when I tried to run "make
>> test_barriers".
>> Also attached are c.txt, m.txt, and mi.txt after the mpich2 install
>> was
>> finished. All the single-machine tests went well.
>> Best,
>> Peter.
