[mpich-discuss] MPICH2 and MPE log
Marc levesqm at emt.inrs.ca
Mon Jun 22 08:07:05 CDT 2009
Well... I don't have MPE2. That's why I took the MPE library from my
MPICH-1 implementation. As said in:
http://www.mcs.anl.gov/research/projects/perfvis/download/index.htm
MPE is supposed to work with any MPI implementation.
However, I know that MPE is old and it is strongly recommended to use
MPE2 instead. The easy solution at the present time would be then to
install it.
Thanks for all.
Marc
On Thu, 2009-06-18 at 15:17 -0500, chan at mcs.anl.gov wrote:
> Try compiling with
> "mpicxx -o helloworld hellowWorld.cc -L/opt/mpich2/gnu/lib -lmpichcxx -llmpe -lmpe"
> Notice I used link flag -L/opt/mpich2/gnu/lib not -L/opt/mpich/gnu/lib.
> I assume MPE2 libraries are built in /opt/mpich2/gnu/lib.
> A.Chan
> ----- "Marc" <levesqm at emt.inrs.ca> wrote:
> > Here's the output with the "-show" argument:
> > $ mpicxx -show -o helloWorld helloWorld.cc -L/opt/mpich/gnu/lib
> > -lmpichcxx -llmpe -lmpe -DMPICH_IGNORE_CXX_SEEK
> > c++ -o helloWorld helloWorld.cc -L/opt/mpich/gnu/lib -lmpichcxx
> > -llmpe
> > -lmpe -DMPICH_IGNORE_CXX_SEEK -I/opt/mpich2/gnu/include
> > -L/opt/mpich2/gnu/lib -Wl,-rpath -Wl,/opt/mpich2/gnu/lib -lmpichcxx
> > -lmpich -lpthread -lrt -luuid -lrt
> > Marc
> > On Thu, 2009-06-18 at 11:39 -0500, chan at mcs.anl.gov wrote:
> > > The MPE in MPICH-1, called mpe, is old.
> > > MPICH2 has its own version of MPE, called mpe2.
> > > I don't see the reason to use MPE from MPICH-1
> > > for MPICH2.
> > > Can you add "-show" to your mpicxx command and
> > > send us the output ?
> > > A.Chan
> > > > The MPE library from MPICH-1 don't seems to work with MPICH-2:
> > > > $ mpicxx -o helloWorld helloWorld.cc -L/opt/mpich/gnu/lib
> > -lmpichcxx
> > > > /opt/mpich2/gnu/lib/libmpichcxx.so: undefined reference to
> > > > `MPI_Lookup_name'
> > > > `MPI_Open_port'
> > > > ... and so on ...
> > > > Is there a way I can fix this without integrating MPE in MPICH-2?
> > > > Thanks for all.
> > > > Marc
> > > > > > Does anyone has tried to compile a MPICH2 code with logging
> > > > option?
> > > > > > When
> > > > > > I follow the syntax from:
> > http://web.mit.edu/AFS/athena.mit.edu/course/13/13.715/mpich2-1.0.6p1/64/www/www1/mpicxx.html
> > > > > 1.0.6p1 is old.  The latest release is 1.1.  You may want to try
> > 1.1
> > > > instead.
> > > > > > I get an error:
> > > > > > mpicxx -mpe=mpilog -o helloWorld helloWorld.cc
> > > > > > cc1plus: error: unrecognized command line option
> > "-mpe=mpilog"
> > > > > This is odd, it looks like -mpe option was passed down to the
> > native
> > > > C++
> > > > > compiler.
> > > > > > I tried to link manually the library with:
> > > > > > mpicxx -o helloWorld helloWorld.cc -L/opt/mpich/gnu/lib -lmpe
> > > > -llmpe
> > > > > > but then I get undefined references from the library liblmpe.
> > > > > > Removing it with:
> > > > > For C++ program, try link with -lmpichcxx -llmpe -lmpe.
> > > > > > compile but does not create log file... Notice that MPE is
> > > > installed
> > > > > > in
> > > > > > the MPICH directory on my machine but it's supposed to work
> > also
> > > > with
> > > > > > MPICH2, right?
> > > > > > Best regards,
> > > > > > Marc
