[mpich-discuss] assertion failed in socksm.c it_plfc->revents when trying mpptest
Pavan Balaji
balaji at mcs.anl.gov
Thu Jun 11 01:37:42 CDT 2009
The problem with the test suite seems quite weird to me. We run the
MPICH2 test suite several times in the nightly scripts as well as for
our local testing every day, and we never saw any such problem.
Does the "cpi" test in your build/examples directory work fine?
$ mpiexec -n 4 ./examples/cpi
-- Pavan
On 06/10/2009 06:07 PM, Gregory Alan Hildstrom wrote:
> Hello. I am trying to set up a simple performance test using mpptest
> between two nodes running a stripped down version of RHEL5 x86_64. I am
> able to mpdboot -n 2 and the subsequent mpdtrace shows the host names of
> both nodes. I ran mpdringtest with no problems. I'm running mpich2-1.1
> and mpptest from perftest-1.4b.
> I ran "mpirun -np 2 mpptest -logscale" and got the following error output.
> Assertion failed in file socksm.c at line 1663: (it_plfd->revents &
> 0x008) == 0
> internal ABORT - process 0
> 0x008) == 0
> internal ABORT - process 1
> rank 0 in job 3 serverhost_37494 caused collective abort of all ranks
> exit status of rank 0: return code 1
> I am not sure if this is an mpich issue or an mpptest issue. I tried to
> make the test suite bundled with mpich2, but it did not build, which is
> why I am trying mpptest. The test suite first complained about a missing
> lib.a, which should have been libmpich.a in test/mpid/ch3's makefile.
> Then it complained about a missing test.h in test/util/timer/timers.c. I
> commented out the include test.h, which resulted in an undefined
> reference to "Test_Waitforall".
> Any suggestions of where to look for problems? I would also appreciate
> any pointers to other mpich-compatible benchmarks or test suites.
> Thank you. -Greg
Pavan Balaji
http://www.mcs.anl.gov/~balaji
