[mpich-discuss] installing mpich2 into mac os
    Ufuk Utku Turuncoglu
    turuncu at ucar.edu
    Thu Jun  4 13:31:02 CDT 2009
Thanks for your help. You can find the files as attachment.
--ufuk
Anthony Chan wrote:
> Can you send us the configure output (the messages that were
> displayed on your screen, i.e. c.txt from "./configure ... 2>&1 | tee c.txt")
> as well as config.log which is generated automatically from configure.
> A.Chan
> ----- "Ufuk Utku Turuncoglu" <turuncu at ucar.edu> wrote:
>> Hi,
>> I try to install mpich2 1.1 to mac os x 10.5.7 using intel compilers.
>> If
>> i leave blank CXX option, it installs without error. I am using
>> following environment variables and configuration command,
>> export FC=ifort
>> export F77=ifort
>> export F90=ifort
>> export FFLAGS="-O3 -xT -align all -fno-alias -m64"
>> export CC=icc
>> export CFLAGS="-no-multibyte-chars -O3 -m64"
>> ./configure --prefix=`pwd` --disable-rlog --enable-fast=O3
>> but if i set environment variables to use intel C++ compiler icpc
>> export CXX=icpc
>> export CXXFLAGS="-no-multibyte-chars -O3 -m64"
>> export CXXCPP="icpc -E"
>> it gives sanity check error for icpc compiler. I also unset CXXCPP but
>> i
>> get still sanity check error. Is there any specific flag to solve
>> this?
>> The intel compiler versions are,
>> Intel(R) Fortran Compiler for applications running on Intel(R) 64,
>> Version 10.1    Build 20070913 Package ID: m_fc_b_10.1.006
>> Intel(R) C Compiler for applications running on Intel(R) 64, Version
>> 10.1    Build 20070913 Package ID: m_cc_p_10.1.006
>> Intel(R) C++ Compiler for applications running on Intel(R) 64, Version
>> Thanks,
>> --ufuk
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090604/7648dfdd/attachment-0001.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090604/7648dfdd/attachment-0001.diff>
