[mpich-discuss] installing mpich2 into mac os
    Anthony Chan
    chan at mcs.anl.gov
    Thu Jun  4 12:46:53 CDT 2009
Can you send us the configure output (the messages that were
displayed on your screen, i.e. c.txt from "./configure ... 2>&1 | tee c.txt")
as well as config.log which is generated automatically from configure.
A.Chan
----- "Ufuk Utku Turuncoglu" <turuncu at ucar.edu> wrote:
> Hi,
> I try to install mpich2 1.1 to mac os x 10.5.7 using intel compilers.
> If
> i leave blank CXX option, it installs without error. I am using
> following environment variables and configuration command,
> export FC=ifort
> export F77=ifort
> export F90=ifort
> export FFLAGS="-O3 -xT -align all -fno-alias -m64"
> export CC=icc
> export CFLAGS="-no-multibyte-chars -O3 -m64"
> ./configure --prefix=`pwd` --disable-rlog --enable-fast=O3
> but if i set environment variables to use intel C++ compiler icpc
> export CXX=icpc
> export CXXFLAGS="-no-multibyte-chars -O3 -m64"
> export CXXCPP="icpc -E"
> it gives sanity check error for icpc compiler. I also unset CXXCPP but
> i
> get still sanity check error. Is there any specific flag to solve
> this?
> The intel compiler versions are,
> Intel(R) Fortran Compiler for applications running on Intel(R) 64,
> Version 10.1    Build 20070913 Package ID: m_fc_b_10.1.006
> Intel(R) C Compiler for applications running on Intel(R) 64, Version
> 10.1    Build 20070913 Package ID: m_cc_p_10.1.006
> Intel(R) C++ Compiler for applications running on Intel(R) 64, Version
> Thanks,
> --ufuk
