[mpich-discuss] IMB fails with tcp/ip 512 processes.
    Devesh Sharma
    devesh28 at gmail.com
    Wed Jun  3 07:48:27 CDT 2009
thanks Guillaume,
Kindly clarify the difference between nemesis and ssm devices. I am
sorry if it sounds silly.
On Wed, Jun 3, 2009 at 6:09 PM, Guillaume Mercier <mercierg at mcs.anl.gov> wrote:
> Hello,
> The MPICH2/Nemesis TCP module uses TCP as protocol, not UDP.
> You can configure it with the option  --with-device:nemesis:tcp
> The TCP module is the default communication network in Nemesis.
> Regards,
> Guillaume
> Devesh Sharma a écrit :
>> thanks sir,
>> I will try out this.
>> Dose new TCP/IP mpi stack still uses UD socket fot data transfer? If
>> yes them what is the difficulty to use TCP socket?
>> On Wed, Jun 3, 2009 at 5:18 PM, Dhabaleswar Panda
>> <panda at cse.ohio-state.edu> wrote:
>>> If you are interested in the TCP/IP interface, you should use the latest
>>> MPICH2 stack (not MVAPICH2 stack). FYI, the TCP/IP interface support in
>>> MVAPICH2-1.2 is similar to that in MPICH2 1.0.7. We released MVAPICH2 1.4
>>> yesterday and it has the TCP/IP support of MPICH2 1.0.8p1.  The latest
>>> version of MPICH2 stack is the 1.1 series. You should use this version to
>>> get the best performance and stability.
>>> Hope this helps.
>>> Thanks,
>>> DK
>>> On Wed, 3 Jun 2009, Devesh Sharma wrote:
>>>> Hello list
>>>> I am trying to run IMB using ssm ADI of MVAPICH2-1.2 on 32 quad socket
>>>> quad core machines. But it is failing because segfault when I run with
>>>> 512 processes.
>>>> Somebody kindly help me to figure out where the problem is.
>>>> -Devesh
