[mpich-discuss] IMB fails with tcp/ip 512 processes.
    Guillaume Mercier
    mercierg at mcs.anl.gov
    Wed Jun  3 07:39:58 CDT 2009
Hello,
The MPICH2/Nemesis TCP module uses TCP as protocol, not UDP.
You can configure it with the option  --with-device:nemesis:tcp
The TCP module is the default communication network in Nemesis.
Guillaume
Devesh Sharma a écrit :
> thanks sir,
> I will try out this.
> Dose new TCP/IP mpi stack still uses UD socket fot data transfer? If
> yes them what is the difficulty to use TCP socket?
> On Wed, Jun 3, 2009 at 5:18 PM, Dhabaleswar Panda
> <panda at cse.ohio-state.edu> wrote:
>> If you are interested in the TCP/IP interface, you should use the latest
>> MPICH2 stack (not MVAPICH2 stack). FYI, the TCP/IP interface support in
>> MVAPICH2-1.2 is similar to that in MPICH2 1.0.7. We released MVAPICH2 1.4
>> yesterday and it has the TCP/IP support of MPICH2 1.0.8p1.  The latest
>> version of MPICH2 stack is the 1.1 series. You should use this version to
>> get the best performance and stability.
>> Hope this helps.
>> Thanks,
>> DK
>> On Wed, 3 Jun 2009, Devesh Sharma wrote:
>>> Hello list
>>> I am trying to run IMB using ssm ADI of MVAPICH2-1.2 on 32 quad socket
>>> quad core machines. But it is failing because segfault when I run with
>>> 512 processes.
>>> Somebody kindly help me to figure out where the problem is.
>>> -Devesh
