[mpich-discuss] mpich2 and pvfs2 error
Dorian Krause
ddkrause at uni-bonn.de
Tue Jul 28 05:10:28 CDT 2009
Hi Rob,
I mixed two pvfs2 versions (2.7.1 and 2.8.1). In between the interface
for PVFS_sys_create changed and I compiled mpich for pvfs2 2.8 but I
linked agains a 2.7 library ...
Thanks for your help!
Dorian
Dorian Krause wrote:
> Rob Latham wrote:
>> On Fri, Jul 24, 2009 at 02:45:53PM +0200, Dorian Krause wrote:
>>> /mnt/pvfs2 kraused$ /home/kraused/mpich2-1.1.1/bin/mpiexec -np 1
>>> /home/kraused/bnchmk/Filesystem/mpio pvfs2:///mnt/pvfs2/abc
>>> [E 14:42:04.891854] invalid (NULL) required argument
>>> [E 14:42:04.891992] PVFS_isys_create call: Invalid argument
>>> [E 14:42:04.892686] invalid (NULL) required argument
>>> [E 14:42:04.892717] PVFS_isys_create call: Invalid argument
>> OK, take two!
>> That 'invalid (NULL) required argument' message comes from this
>> stanza:
>> if ((parent_ref.handle == PVFS_HANDLE_NULL) ||
>> (parent_ref.fs_id == PVFS_FS_ID_NULL) ||
>> (object_name == NULL) || (resp == NULL))
>> gossip_err("invalid (NULL) required argument\n");
>> return ret;
>> - 'resp' can't be null: we're declaring it on the stack in ROMIO
>> - 'object_name' is the filename: probably ok
>> - 'parent_ref' seems like the most likely suspect.
>> I wonder if something is getting confused with the multiple /// in the
>> path name? What does '/proc/mounts'
> The relevant line in /proc/mounts is
> tcp://cub:3334/pvfs2-fs /mnt/pvfs2 pvfs2 rw 0 0
>> or your fstab
> This is the line:
> LABEL=/pvfs /pvfs ext3
> defaults 1 2
>> or your pvfs2tab
> I don't have a /etc/pvfs2tab, only the /etc/fstab but I suspect this
> is normal ?!
>> entry look like?
>> What happens if you call your test with 'pvfs2:/mnt/pvfs2/abc' ?
> The same,
> /home/kraused/bnchmk/Filesystem/mpio pvfs2:/mnt/pvfs2/abc
> [E 16:37:17.811641] invalid (NULL) required argument
> [E 16:37:17.811782] PVFS_isys_create call: Invalid argument
> [E 16:37:17.812253] invalid (NULL) required argument
> [E 16:37:17.812279] PVFS_isys_create call: Invalid argument
> MPI_File_open returned -524286
> MPI_Error_string(-524286) = Undefined dynamic error code
> In fact, if I touch /mnt/pvfs2/abc before calling the test, every
> works. I can also do
> /home/kraused/bnchmk/Filesystem/mpio ufs://mnt/pvfs2/abc
> MPI_File_open returned 0
> MPI_Error_string(0) = No MPI error
> without any problems.
> Thanks,
> Dorian
>> ==rob
