[mpich-discuss] mpich2 and pvfs2 error
Dorian Krause
ddkrause at uni-bonn.de
Fri Jul 24 09:42:51 CDT 2009
Rob Latham wrote:
> On Fri, Jul 24, 2009 at 02:45:53PM +0200, Dorian Krause wrote:
>> /mnt/pvfs2 kraused$ /home/kraused/mpich2-1.1.1/bin/mpiexec -np 1
>> /home/kraused/bnchmk/Filesystem/mpio pvfs2:///mnt/pvfs2/abc
>> [E 14:42:04.891854] invalid (NULL) required argument
>> [E 14:42:04.891992] PVFS_isys_create call: Invalid argument
>> [E 14:42:04.892686] invalid (NULL) required argument
>> [E 14:42:04.892717] PVFS_isys_create call: Invalid argument
> OK, take two!
> That 'invalid (NULL) required argument' message comes from this
> stanza:
> if ((parent_ref.handle == PVFS_HANDLE_NULL) ||
> (parent_ref.fs_id == PVFS_FS_ID_NULL) ||
> (object_name == NULL) || (resp == NULL))
> gossip_err("invalid (NULL) required argument\n");
> return ret;
> - 'resp' can't be null: we're declaring it on the stack in ROMIO
> - 'object_name' is the filename: probably ok
> - 'parent_ref' seems like the most likely suspect.
> I wonder if something is getting confused with the multiple /// in the
> path name? What does '/proc/mounts'
The relevant line in /proc/mounts is
tcp://cub:3334/pvfs2-fs /mnt/pvfs2 pvfs2 rw 0 0
> or your fstab
This is the line:
LABEL=/pvfs /pvfs ext3 defaults 1 2
> or your pvfs2tab
I don't have a /etc/pvfs2tab, only the /etc/fstab but I suspect this is
normal ?!
> entry look like?
> What happens if you call your test with 'pvfs2:/mnt/pvfs2/abc' ?
The same,
/home/kraused/bnchmk/Filesystem/mpio pvfs2:/mnt/pvfs2/abc
[E 16:37:17.811641] invalid (NULL) required argument
[E 16:37:17.811782] PVFS_isys_create call: Invalid argument
[E 16:37:17.812253] invalid (NULL) required argument
[E 16:37:17.812279] PVFS_isys_create call: Invalid argument
MPI_File_open returned -524286
MPI_Error_string(-524286) = Undefined dynamic error code
In fact, if I touch /mnt/pvfs2/abc before calling the test, every works.
I can also do
/home/kraused/bnchmk/Filesystem/mpio ufs://mnt/pvfs2/abc
MPI_File_open returned 0
MPI_Error_string(0) = No MPI error
without any problems.
Dorian
> ==rob
