[mpich-discuss] thread MPI calls
Pavan Balaji
balaji at mcs.anl.gov
Fri Jul 24 20:00:05 CDT 2009
If only the master thread is making MPI calls, you should run it in
MPI_THREAD_FUNNELED mode.
MPI_THREAD_MULTIPLE is the most generic option where all threads can
make MPI calls -- this can handle all kinds of threaded application. But
this generality comes with a performance penalty. In your case, since
only one thread is making MPI calls, you don't have to pay this
-- Pavan
On 07/24/2009 07:49 PM, chong tan wrote:
> sorry that i ovr cleaned my inbox, this is the only one I have left to
> continue with
> this thread.
> After cleaning up some over-looked situation and making sure that we are
> running with
> MPI_Init_thread with THREAD_MULTIPLE, we rerun a few tests, we
> are seeing up to 10% performance drop compared to un-thread code. We
> used affinity,
> the main and the spawned thread are running on different core of the
> same physical CPU.
> We use posix thread to create our thread, is that bad for MPI ?
> ta
> *From:* chong tan <chong_guan_tan at yahoo.com>
> *To:* mpich-discuss at mcs.anl.gov
> *Sent:* Thursday, July 23, 2009 3:40:51 PM
> *Subject:* [mpich-discuss] thread MPI calls
> box X86 box running Linux. MPICH2 1.1 configured with
> --disable-f77 --disable-f90 --with-device=ch3:nemesis --enable-fast
> machine : 16 cores, load of mem. running with mpiexec -n 4
> The master process (MPICH rank 0) has 2 thread, main and recv, the
> locks are constructed using pthread. The master's
> recv function wait for the recv thread to be done with all recieving,
> then process the data, and reenable the recv thread,
> like this:
> main recv thread
> recvFunc() { wait for 'run'
> wait for read-done for n processes
> apply data
> call MPI_IRecv
> signal run MPI_waitall
> signal read-done
> recvFunc is repeatedly called during the life of my applications. (In a
> few tests I have, it is called 100+ billion times)
> compared to the same application with no thread and using IRecv or Recv,
> the threaded version can run 20+%
> slower. From the process monitoring, it looks like the MPI Irecv calls
> maybe thread. This performance degration
> is inline with 2.0.6 configured using --enable-threads=funneled. The
> application ran for many hours, so 20% is
> significant.
> Questions :
> - is MPICH2 1.1 self-sensing ? that is, does it know it can decide if
> it has to do thread-multiple ?
> - IRecv and MPI wait all, is that also threaded ?
> - anyone experimented this before ?
> thanks
> tan
> *From:* Rajeev Thakur <thakur at mcs.anl.gov>
> *Sent:* Friday, June 26, 2009 12:12:18 PM
> *Subject:* Re: [mpich-discuss] does 1.1 support real threading of MPI call ?
> Yes, it supports MPI_THREAD_MULTIPLE as defined by the MPI standard.
> Rajeev
> *From:* mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *chong tan
> *Sent:* Friday, June 26, 2009 2:04 PM
> *Subject:* [mpich-discuss] does 1.1 support real threading of MPI call ?
> Does anyone know if the 1.1 release supports real threaded MPI
> calls. That is,
> a process, say 1, may contain n threads, and each calling
> MPI_Send/Recv to
> other processes, but still think they are all process 1 ?
> I am not looking at the funneled solution, that does not help me.
> thanks
> tan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
