[mpich-discuss] thread MPI calls
chong tan chong_guan_tan at yahoo.com
Fri Jul 24 19:49:53 CDT 2009
sorry that i ovr cleaned my inbox, this is the only one I have left to continue with
this thread.
After cleaning up some over-looked situation and making sure that we are running with
MPI_Init_thread with THREAD_MULTIPLE, we rerun a few tests, we
are seeing up to 10% performance drop compared to un-thread code.  We used affinity,
the main and the spawned thread are running on different core of the same physical CPU.
We use posix thread to create our thread, is that bad for MPI ?
ta
Sent: Thursday, July 23, 2009 3:40:51 PM
Subject: [mpich-discuss] thread MPI calls
box X86 box running Linux.  MPICH2 1.1 configured with
 --disable-f77 --disable-f90 --with-device=ch3:nemesis  --enable-fast
machine : 16 cores, load of mem.  running  with mpiexec -n 4
The master process (MPICH rank 0) has 2 thread, main and recv, the locks are constructed using pthread.   The master's
recv function wait for the recv thread to be done with all recieving, then process the data, and reenable the recv thread,
like this:
             main                                                recv thread
             recvFunc() {                                   wait for 'run'
             wait for read-done                          for n processes
             apply data                                              call MPI_IRecv
             signal run                                        MPI_waitall
             }                                                      signal read-done
recvFunc is repeatedly called during the life of my applications.  (In a few tests I have, it is called 100+ billion times)
compared to the same application with no thread and using IRecv or Recv, the threaded version can run 20+%
slower.  From the process monitoring, it looks like the MPI Irecv calls maybe thread. This performance degration
is inline with 2.0.6 configured using --enable-threads=funneled.  The application ran for many hours, so 20% is
significant.
Questions :
-  is MPICH2 1.1 self-sensing ?  that is, does it know it can decide if it has to do thread-multiple ?
-  IRecv and MPI wait all, is that also threaded ?
-  anyone experimented this before ?
thanks
tan
Sent: Friday, June 26, 2009 12:12:18 PM
Subject: Re: [mpich-discuss] does 1.1 support real threading of MPI call ?
Yes, it supports MPI_THREAD_MULTIPLE as defined by the MPI standard.
Rajeev
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of chong tan
>Sent: Friday, June 26, 2009 2:04 PM
>Subject: [mpich-discuss] does 1.1 support real threading of MPI call ?
>Does anyone know if the 1.1 release supports real threaded MPI calls.  That is,
>a process, say 1, may contain n threads, and each calling MPI_Send/Recv to
>other processes, but still think they are all process 1 ?
>I am not looking at the funneled solution, that does not help me.
>thanks
>tan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090724/b46dbd59/attachment-0001.htm>
