[mpich-discuss] I wonder if my mpdboot is the cause of problem...help me!
Pavan Balaji
balaji at mcs.anl.gov
Sat Jul 18 00:12:54 CDT 2009
Does mpdtrace show both nodes? Which version of MPICH2 are you using?
-- Pavan
On 07/18/2009 12:05 AM, Gra zeus wrote:
> hello,
> thx for answer yesterday.
> I tested my code in one machine (with"mpiexec -n 2 ./myprog"),everything
> work fine - my program can use MPI_Send,MPI_Recv without any problems.
> today, I setup mpich2 on two machines. Both machines can communicate
> with others, ssh are tested on both machines, mpd work, mpdringtest work.
> however,when i run my program that use MPI_Send and MPI_Recv, MPI_Recv
> is blocked forever.
> so i write new simple code to test MPI_Send,MPI_Recv like this
> int myrank;
> MPI_Status status;
> MPI_Init( &argc, &argv );
> MPI_Comm_rank( MPI_COMM_WORLD, &myrank );
> if (myrank == 0)
> int senddata = 1;
> MPI_Send(&senddata, 1, MPI_INT, 1, 0, MPI_COMM_WORLD);
> else if (myrank == 1)
> int recvdata = 0;
> MPI_Recv(&recvdata, 1, MPI_INT, 0, 0, MPI_COMM_WORLD, &status);
> printf("received :%d:\n", recvdata);
> MPI_Finalize();
> i got this error
> Assertion failed in file ch3_progress.c at line 489: pkt->type >= 0 &&
> pkt->type < MPIDI_NEM_PKT_END
> internal ABORT - process 1
> Fatal error in MPI_Finalize: Other MPI error, error stack:
> MPI_Finalize(315)..................: MPI_Finalize failed
> MPI_Finalize(207)..................:
> MPID_Finalize(92)..................:
> PMPI_Barrier(476)..................: MPI_Barrier(comm=0x44000002) failed
> MPIR_Barrier(82)...................:
> MPIC_Sendrecv(164).................:
> MPIC_Wait(405).....................:
> MPIDI_CH3I_Progress(150)...........:
> MPID_nem_mpich2_blocking_recv(1074):
> MPID_nem_tcp_connpoll(1667)........:
> state_commrdy_handler(1517)........:
> MPID_nem_tcp_recv_handler(1413)....: socket closed
> I also tried example/cpi that come with install package -> result is the
> example program freezed, without any errors.(I assume it stopped at
> MPI_Bcast())
> Can anyone help me with this?
> This code and my program can run smoothly when I use 1 machine (with
> option , -n 2, -n 4 .... etc) but whenever I start mpdboot with 2
> machines, mpi processes can't communicate with other mpi processes via
> MPI_Send,MPI_Recv.
> thx,
> gra
Pavan Balaji
http://www.mcs.anl.gov/~balaji
