[mpich-discuss] question about running mpich2 on sol86
    Shangli Wu
    shangliw at cadence.com
    Wed Jul  8 14:22:18 CDT 2009
I try to build the code with CC, it got link errors on sol86. I can
build and run cpi.c using same makefile without problem (on sol86).
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 >
make
@=== Loading ./ems0.exe:   CC ...
Undefined               first referenced
 symbol                     in file
void MPI::Get_processor_name(char*,int&) ./cxxpi.o
double MPI::Wtime()                 ./cxxpi.o
MPI::COMM_WORLD                ./cxxpi.o
[Hint: static member MPI::COMM_WORLD must be defined in the program]
void MPI::Finalize()              ./cxxpi.o
void MPI::Init(int&,char**&)            ./cxxpi.o
MPI::Datatype::__vtbl           ./cxxpi.o
[Hint: try checking whether the first non-inlined, non-pure virtual
function of class MPI::Datatype is defined]
ld: fatal: Symbol referencing errors. No output written to ./ems0.exe
*** Error code 1
clearmake: Error: Build script failed for "ems0.exe"
Any suggestion?
Thanks
Shangli
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
	Sent: Wednesday, July 08, 2009 2:03 PM
	Subject: Re: [mpich-discuss] question about running mpich2 on
sol86
	You need to specify the directory containing the C++ compiler
libraries in the environment variable LD_LIBRARY_PATH or build MPICH2
without shared libraries. (The default build is without shared
librares.)
	Also try compiling and running a simple C++ program directly
with the C++ compiler, not mpicxx.
	Rajeev
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Shangli Wu
		Sent: Wednesday, July 08, 2009 11:47 AM
		Subject: [mpich-discuss] question about running mpich2
on sol86
		I try to build/run the example cxxpi.cxx on Sol86 using
mpicxx. Compile seems OK. But when I run it, it shows error as:
mpicxx cxxpi.cxx
ls
		a.out       cxxpi.cxx   cxxpi.cxx~
a.out
		ld.so.1: a.out: fatal: libstdc++.so.5: open failed: No
such file or directory
		Killed
mpd&
		[1] 779
mpiexec -n 2 a.out
		The same file can build/run on Sun4v/Linux without any
problem. Would someone help me to understand what's wrong on Sol86?
		Thanks
		Shangli Wu
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090708/e679dd2e/attachment.htm>
