[mpich-discuss] question about running mpich2 on sol86
Rajeev Thakur
thakur at mcs.anl.gov
Wed Jul 8 13:03:27 CDT 2009
You need to specify the directory containing the C++ compiler libraries in the environment variable LD_LIBRARY_PATH or build MPICH2
without shared libraries. (The default build is without shared librares.)
Also try compiling and running a simple C++ program directly with the C++ compiler, not mpicxx.
Rajeev
_____
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Shangli Wu
Sent: Wednesday, July 08, 2009 11:47 AM
Subject: [mpich-discuss] question about running mpich2 on sol86
I try to build/run the example cxxpi.cxx on Sol86 using mpicxx. Compile seems OK. But when I run it, it shows error as:
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 > mpicxx cxxpi.cxx
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 > ls
a.out cxxpi.cxx cxxpi.cxx~
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 > a.out
ld.so.1: a.out: fatal: libstdc++.so.5: open failed: No such file or directory
Killed
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 > mpd&
[1] 779
chfcsx023:/home/shangliw/libraries/mpich2-1.0.8p1/examples/testcase_1 > mpiexec -n 2 a.out
The same file can build/run on Sun4v/Linux without any problem. Would someone help me to understand what's wrong on Sol86?
Thanks
Shangli Wu
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090708/a0f3d799/attachment.htm>
