[mpich-discuss] CLOG write failure
    Anthony Chan
    chan at mcs.anl.gov
    Fri Feb 27 11:56:42 CST 2009
If TMPDIR is not set or it is not read by MPE for some
reasons, /tmp will be used for local storage.
The error message below shows that /tmp_proj is used
for local clog2 file, can you check if you have write
permission to /tmp_proj ?
A.Chan
----- "chong tan" <chong_guan_tan at yahoo.com> wrote:
> we ran our application, after a few hours, MPICH run into file write
> error and aborted. THe error :
> clog_buffer.c:CLOG_Buffer_localIO_write() -
>         Fail to write to the temporary logfile
> /tmp_proj/clog2_BgxoHx_taskID=000003.
>         Check if the filesystem where the logfile resides is full.
> If so, set environmental variable TMPDIR to a bigger filesystem.
> tried setting TMPDIR to a disk with more than 20G of free space, still
> get the same error.
> When it failed, the temporary log file was about 360M.
> we ran 'limit' and filesize was set to unlimited.
> any suggestion ?
> thanks
> tan
