[mpich-discuss] HP-XC 3000 cluster issues
Rajeev Thakur
thakur at mcs.anl.gov
Wed Feb 25 12:35:56 CST 2009
> On a sidenote, how do I reply to the thread? I only get the daily digest
in mail.
You can change you subscription options at
https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss to receive each
mail separately instead of a digest version.
Rajeev
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gauri Kulkarni
Sent: Wednesday, February 25, 2009 6:04 AM
Subject: Re: [mpich-discuss] HP-XC 3000 cluster issues
Thanks, Rajeev.
Is it the same case with MPICH1? The reason I need info about MPICH1 with
SLURM is because we have a software (FastDL) which has been compiled with
MPICH1. We have asked the vendor to give us the software recompiled with
MPICH2, but honestly, we do not know any particular advantage using MPICH2
over MPICH1 (apart from the fact that MPICH1 isn't maintained anymore).
On a sidenote, how do I reply to the thread? I only get the daily digest in
mail.
-Gauri.
Message: 4
Date: Mon, 23 Feb 2009 23:38:06 -0600
To: <mpich-discuss at mcs.anl.gov>
Message-ID: <
72376B2D10EC43F9A0A433C960F951B6 at thakurlaptop>
Content-Type: text/plain; charset="us-ascii"
To run MPICH2 with SLURM, configure with the options "--with-pmi=slurm
--with-pm=no" as described in the MPICH2 README file. Also see the
instructions on how to run MPICH2 with SLURM at
https://computing.llnl.gov/linux/slurm/quickstart.html .
Rajeev
_____
Sent: Monday, February 23, 2009 11:19 PM
Subject: [mpich-discuss] HP-XC 3000 cluster issues
I am a newbie to the MPI in general. Currently in our institute, we have a
cluster of 16nodes-8processors. It is an HP-XC 3000 cluster which basically
means, it's quite proprietary. It has its own MPI implementation - HP-MPI -
in which, the parallelization is managed by SLURM (Simple Linux Utility for
Resource Management). There is also a batch job scheduler - LSF (Load
Sharing Facility) which works in tandem with SLURM to parallelize the batch
jobs. We have installed both MPICH and MPICH2 and are testing it, but we are
running into compatibility issues. For a simple helloworld.c program:
1. For HPMPI: Compiled with mpicc of this implemetation and executed with
its mpirun: mpirun -np 4 helloworld works correctly. For batch scheduling,
we need to isse "bsub -n4 [other options] mpirun -srun helloworld" and it
runs fine too. "srun" is SLURM utility that parallelizes the jobs.
2. For MPICH and mPICH2: Again, compiled with mpicc of these respective
implemetations and executed with their own mpirun:
i) mpirun -np 4 helloword : Works.
ii) mpirun -np 15 helloworld: The parallelization is limited to just a
single node - that is 8 processes run first on 8 processors of a single node
and then remaining ones.
iii) bsub -n4 [options] mpirun -srun hellowrold: Job terminated. srun
option not recognized.
iv) bsub [options] mpirun -np 4 helloworld: Works
V) bsub [options] mpirun -np 15 helloworld: (Same as iii)
Anybody aware of HP cluster issues with MPICH? Am I misinterpreting? Any
help is appreciated.
Gauri.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090225/f963e034/attachment.htm>
