[mpich-discuss] MPICH on intel x86_64 core2 quad + fedora 10
Rajeev Thakur
thakur at mcs.anl.gov
Sat Feb 21 10:13:38 CST 2009
Does the cpi example in the examples directory run? If you do "make testing"
in the top-level mpich2 directory it will run the entire test suite in
test/mpi (takes an hour). If these programs run, the problem is likely in
your application or the way it is compiled or something like that.
Rajeev
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dhiraj
Sent: Saturday, February 21, 2009 4:47 AM
Subject: Re: [mpich-discuss] MPICH on intel x86_64 core2 quad + fedora 10
Dear Rajeev,
I followed steps from installation guide and used MPICH2 with mentioned
configure option.
If I do I get following outputs,
# mpd & --- starts mpd
# mpdtrace
COMB2 (hostname of my machine)
# mpdallexit
exits mpd
I have compiled the parallel code and run when mpd is on using following
command
# mpirun -n 4 ./BURN
(BURN is executable file).... The program execution hangs and I have to do
``ctrl + c''
I get following message,
^CTraceback (most recent call last):
File "<stdin>", line 811, in <module>
File "<stdin>", line 374, in mpdboot
File "<string>", line 1, in connect_ex
KeyboardInterrupt
I am having no clue about what is happening. Please help me in this regard.
Yours,
Dhiraj.
2009/2/20 Rajeev Thakur <thakur at mcs.anl.gov>
You can just follow the instructions in the MPICH2 installation guide. You
can use MPICH2 1.0.8 and configure with the option --with-device=ch3:nemesis
Rajeev
_____
Sent: Thursday, February 19, 2009 11:11 PM
Subject: [mpich-discuss] MPICH on intel x86_64 core2 quad + fedora 10
Dear Sir,
I want to install MPICH library on intel x86_64 core2 quad + fedora 10 (OS).
I seek your help regarding an installation guide and ``hello_world'' program
execution guide
for this shared memory multi-core machine.
With warm regards,
Dhiraj Patil
IISc, Bangalore.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090221/1efbddee/attachment.htm>
