[mpich-discuss] Running mpiexec on WIndows Computers
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Feb 20 14:26:28 CST 2009
To analyse the logs they have to be from a single MPI job run. From your
email it looks like the outputs are from multiple runs.
Please provide me 3 log files collected as per instructions below,
1) Run smpd on machine 1, m1, using the command.
smpd -d > smpd_debug_m1.log
2) Run smpd on machine 2, m2, using the command,
smpd -d > smpd_debug_m2.log
3) Now run mpiexec in verbose mode using the command,
mpiexec -verbose -machinefile mf.txt c:\temp\cpi.exe >
mpiexec_verbose.log
jayesh
_____
Sent: Friday, February 20, 2009 1:40 PM
To: Jayesh Krishna
Subject: Re: [mpich-discuss] Running mpiexec on WIndows Computers
in logs-with-verbose.rar are compressed logs from machine 2, with
-verbose option on.
other two logs (smpd-m1.rar and smpd-m2.rar) are logs from machine1 and
machine2 smpd processes, without -verbose option on and without logging
mpiexec process at all.
Sole
On Fri, Feb 20, 2009 at 4:52 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
Send me a detailed email with what each rar file contains (atleast one of
the outputs show that you aborted the job after cpi prompter for user
input)
Also see if you can run non-MPI jobs like hostname on your machines
(mpiexec -n 2 -machinefile mf.txt hostname).
-Jayesh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090220/6022466a/attachment.htm>
