[mpich-discuss] Running mpiexec on WIndows Computers
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Feb 19 10:36:39 CST 2009
>> can you tell me your configuration of win machines that works?  ...
 Nothing special. MPICH2 is installed on both winxp machines, firewalls
turned off. I have already registered the username/password on the
machines. Then I just run cpi.exe.
 I have SP3 installed on both the machines (That is unlikely to be the
cause of your problem). If the Security Center shows that the firewall is
on, you might have a third-party firewall installed on your machine which
is turned on.
Jayesh
  _____
Sent: Thursday, February 19, 2009 10:02 AM
To: Jayesh Krishna
Subject: Re: [mpich-discuss] Running mpiexec on WIndows Computers
I have an administrator account on both machines, so I can do it, but, on
machine2 it is service pack 3 installed..
maybe that's reason that I can't turn off firewall..
so it shows in main Security Center window that firewall is on, and when I
try to turn it off it shows that firewall is actually turned off..
but, I'm not sure that firewall is a problem, because cpi.exe works when
only one job is submited on any of machines...
On Thu, Feb 19, 2009 at 4:46 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
>> I turned off firewalls, but on machine2 it still is showing that
firewall is on, and when I go to turn it off, it is presented that
firewall is off.. ??
 Can you check with a system administrator regarding this (firewall
showing "on" when it is turned off) ? Did you try rebooting the machine
after turning the firewall off ?
Jayesh
  _____
Sent: Thursday, February 19, 2009 9:44 AM
To: Jayesh Krishna
No, I just got my first MPICH2.. and started to work with it..
On Thu, Feb 19, 2009 at 4:42 PM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
 Did you have an older version of MPICH2 and recently upgrade to the
latest version ?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090219/6434448b/attachment.htm>
