[mpich-discuss] mpd and login node
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Feb 13 21:24:33 CST 2009
Use the "-1" option to mpiexec to prevent the first process from being run
on the local node.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Stephen Siegel
> Sent: Friday, February 13, 2009 7:21 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpd and login node
> No queuing system.   Each user just runs mpd, and has a machine file
> that lists the nodes in their home directory.   They are supposed to
> terminate the mpd ring when they are done.   We are not too
> concerned
> with overloading---this is just being used by an introductory
> parallel programming class.  A queuing system would probably
> be a good idea though.  All the machines are running linux.
> On Feb 13, 2009, at 8:14 PM, Reuti wrote:
> > Am 14.02.2009 um 02:06 schrieb Stephen Siegel:
> >> I am running mpich2 with mpd on a small cluster.   We have a
> >> separate logon node which users will log on to, compile, and
> >> execute programs using mpiexec.   We want to configure mpd
> so that
> >> it will distribute the processes over the nodes of the cluster,
> >> excluding the logon node.   For some reason we could not
> figure out
> >> how to do this----the logon node itself ends up getting
> some of the
> >> processes.   Does anyone know how to do this?  Thanks.
> > How are you distributing other jobs right now and avoid
> overloading of
> > certain machines - you have a queuing system like SUN Grid Engine?
> > -- Reuti
