[mpich-discuss] mpd and login node
Stephen Siegel
siegel at cis.udel.edu
Fri Feb 13 19:20:38 CST 2009
No queuing system. Each user just runs mpd, and has a machine file
that lists the nodes in their home directory. They are supposed to
terminate the mpd ring when they are done. We are not too concerned
with overloading---this is just being used by an introductory
parallel programming class. A queuing system would probably be a good
idea though. All the machines are running linux.
On Feb 13, 2009, at 8:14 PM, Reuti wrote:
> Am 14.02.2009 um 02:06 schrieb Stephen Siegel:
>> I am running mpich2 with mpd on a small cluster. We have a
>> separate logon node which users will log on to, compile, and
>> execute programs using mpiexec. We want to configure mpd so that
>> it will distribute the processes over the nodes of the cluster,
>> excluding the logon node. For some reason we could not figure out
>> how to do this----the logon node itself ends up getting some of the
>> processes. Does anyone know how to do this? Thanks.
> How are you distributing other jobs right now and avoid overloading
> of certain machines - you have a queuing system like SUN Grid Engine?
> -- Reuti
