[mpich-discuss] mpich2-1.0.8 OpenSolaris
Jim Langston
Jim.Langston at Sun.COM
Wed Feb 4 14:25:57 CST 2009
Hi All,
I'm trying to build 1.0.8 for OpenSolaris (x86) using
Sun Studio 12, everything builds ok - but when
I try to build an example:
langston at alpha:~/MPICH/mpich2-1.0.8/examples$ rm cpi.o
langston at alpha:~/MPICH/mpich2-1.0.8/examples$ gmake cpi
../bin/mpicc -I../src/include -I../src/include -c cpi.c
../bin/mpicc -o cpi cpi.o -lm
Undefined first referenced
symbol in file
MPIDU_Process_unlock
/export/home/langston/MPICH/mpich2-1.0.8/lib/libmpich.so
MPIDU_Process_lock
MPIDU_Process_lock_init
ld: fatal: Symbol referencing errors. No output written to cpi
gmake: *** [cpi] Error 1
My configuration line is:
langston at alpha:~/MPICH/mpich2-1.0.8$ head config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.62. Invocation command line was
$ ./configure --prefix=/usr/local/mpich2 --enable-threads
--with-thread-package=posix --enable-sharedlibs=solaris-x86
## Platform. ##
I added in solaris-x86 into the configure file to recognize I'm on an
OpenSolaris system which
I've included.
Looking at libmpich.so
langston at alpha:~/MPICH/mpich2-1.0.8/lib$ nm libmpich.so | grep
U MPIDU_Process_unlock
and
langston at alpha:~/MPICH/mpich2-1.0.8/src/mpid/common/locks$ nm
mpidu_atomic_primitives.o
00000000 b Bbss.bss
00000000 d Ddata.data
00000000 r Drodata.rodata
00000000 D emulation_lock
U MPID_Abort
00000024 T MPIDU_Atomic_add_emulated
00000210 T MPIDU_Atomic_cas_aint_emulated
00000164 T MPIDU_Atomic_cas_int_emulated
000000bc T MPIDU_Atomic_cas_int_ptr_emulated
000002bc T MPIDU_Atomic_decr_and_test_emulated
00000364 T MPIDU_Atomic_decr_emulated
000003f8 T MPIDU_Atomic_fetch_and_add_emulated
0000049c T MPIDU_Atomic_fetch_and_decr_emulated
0000053c T MPIDU_Atomic_fetch_and_incr_emulated
000005e0 T MPIDU_Atomic_incr_emulated
000007c8 T MPIDU_Atomic_swap_aint_emulated
00000720 T MPIDU_Atomic_swap_int_emulated
00000678 T MPIDU_Atomic_swap_int_ptr_emulated
00000000 T MPIDU_Interprocess_lock_init
U MPIDU_Process_lock
U MPIDU_Process_lock_init
U MPIU_Internal_error_printf
Any thoughts ? hints ?
thanks,
Jim
Jim Langston
Sun Microsystems, Inc.
(877) 854-5583 (AccessLine)
(513) 702-4741 (Cell)
AIM: jl9594
jim.langston at sun.com
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090204/19d8f38f/attachment-0001.zip>
