[mpich-discuss] configure: different behaviour for bitypes.hontwo machines
Siegmar Gross Siegmar.Gross at informatik.fh-fulda.de
Tue Feb 3 08:50:50 CST 2009
> One possibility is that you have different runtime environments on these
> 2 machines.  We have seen some cygwin environment, e.g. PS1, contains
> some invalid characters, that somehow corrupts the return of last running
> command.
> > tyr 95 diff log.configure.Cygwin.x86.eiger
> > log.configure.Cygwin.x86.wi23 | more
> > 2c2
> > < Running on system: CYGWIN_NT-5.1 eiger 1.5.25(0.156/4/2) 2008-06-12
> > 19:34 i686
> > Cygwin
> > > Running on system: CYGWIN_NT-5.1 wi23 1.5.25(0.156/4/2) 2008-06-12
> > 19:34 i686
> > Cygwin
> > 81,85c81,82
> > < checking whether make supports include... no
> > < checking whether make allows comments in actions... no
> > < configure: WARNING: Your make does not allow comments in target
> > code.
> > < Using this make may cause problems when building programs.
> > < You should consider using gnumake instead.
> > > checking whether make supports include... yes
> > > checking whether make allows comments in actions... yes
> > 146c143
> > < checking for sys/bitypes.h... no
> > > checking for sys/bitypes.h... yes
I don't see any strange differences in the two environments.
tyr cygwin 83 diff env-sort-eiger.txt env-sort-wi23.txt
5c5
CLASSPATH=c:\\Programme\\junit4.4\\junit-4.4.jar;c:\\Programme\\junit4.4;c:\\Pro
gramme\\JMF2.1.1e\\lib\\customizer.jar;c:\\Programme\\JMF2.1.1e\\lib\\jmf.jar;c:
\\Programme\\JMF2.1.1e\\lib\\mediaplayer.jar;c:\\Programme\\JMF2.1.1e\\lib\\mult
iplayer.jar;c:\\Programme\\JMF2.1.1e\\lib\\sound.jar;c:\\Programme\\jdk1.6.0_02\
\lib\\ext\\j3dcore.jar;c:\\Programme\\jdk1.6.0_02\\lib\\ext\\j3dutils.jar;c:\\Pr
ogramme\\jdk1.6.0_02\\lib\\ext\\vecmath.jar;.
CLASSPATH=c:\\Programme\\jdk1.6.0_11\\lib\\ext\\j3dcore.jar;c:\\Programme\\jdk1.
6.0_11\\lib\\ext\\j3dutils.jar;c:\\Programme\\jdk1.6.0_11\\lib\\ext\\vecmath.jar
7c7
< COMPUTERNAME=EIGER
> COMPUTERNAME=WI23
16c16
< DISPLAY=eiger:0.0
> DISPLAY=wi23:0.0
23,25c23,25
< HOMEPATH=\Dokumente und Einstellungen\Admin
< HOST=eiger
< HOSTNAME=eiger
> HOMEPATH=\
> HOST=wi23
> HOSTNAME=wi23
27c27
< HOST_NAME=eiger
> HOST_NAME=wi23
29,31c29,30
< JAVA_HOME=/cygdrive/c/Programme/jdk1.6.0_02
< JDK_HOME=/cygdrive/c/Programme/jdk1.6.0_02
< JMFHOME=/cygdrive/c/Programme/JMF2.1.1e
> JAVA_HOME=/cygdrive/c/Programme/jdk1.6.0_11
> JDK_HOME=/cygdrive/c/Programme/jdk1.6.0_11
35c34
< LOGONSERVER=\\EIGER
> LOGONSERVER=\\WI23
40,41c39,40
MANPATH=/cygdrive/c/Programme/jdk1.6.0_02/man::/usr/ssl/man:/usr/share/qt3/doc/m
an:/usr/X11R6/man:/home/Admin/Cygwin/x86/man:/usr/ssl/man:/usr/share/qt3/doc/man
:/usr/X11R6/man
< NUMBER_OF_PROCESSORS=2
MANPATH=/cygdrive/c/Programme/jdk1.6.0_11/man::/usr/ssl/man:/home/Admin/Cygwin/x
86/man:/usr/ssl/man
> NUMBER_OF_PROCESSORS=4
45c44
PATH=/cygdrive/c/Programme/JMF2.1.1e/bin:/cygdrive/c/Programme/jdk1.6.0_02/bin:/
usr/bin:/usr/X11R6/bin:/usr/autotool/devel/bin:/sbin:/usr/sbin:/usr/local/bin:/u
sr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/c/WINDOWS/system32:/cygdrive
/c/WINDOWS:/cygdrive/c/WINDOWS/System32/Wbem:/cygdrive/c/Programme/Intel/DMIX:/c
ygdrive/c/Programme/ATI:Technologies/ATI.ACE/Core-Static:"C:/Programme/Zone:Labs
/ZoneAlarm/MailFrontier":/cygdrive/c/Programme/QuickTime/QTSystem:/cygdrive/c/Pr
ogramme/jdk1.6.0_02/bin:/cygdrive/c/cmd:/cygdrive/c/emacs:c/cygwin/bin:/cygdrive
/c/WW20:/usr/lib/lapack:/home/Admin/Cygwin/x86/bin:/home/Admin/Cygwin/x86/lib:.
PATH=/cygdrive/c/Programme/jdk1.6.0_11/bin:/usr/bin:/usr/X11R6/bin:/usr/autotool
/devel/bin:/sbin:/usr/sbin:/usr/local/bin:/usr/local/bin:/usr/bin:/bin:/cygdrive
/c/oraclexe/app/oracle/product/10.2.0/server/bin:/cygdrive/c/oracle/product/10.2
.0/client_1/bin:/cygdrive/c/WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WIN
DOWS/System32/Wbem:/cygdrive/c/WINDOWS/system32/nls:/cygdrive/c/WINDOWS/system32
/nls/DEUTSCH:/cygdrive/c/Programme/CollabNet:Subversion:/usr/bin:/home/Admin/Cyg
47d45
< PKG_CONFIG_PATH=/usr/X11R6/lib/pkgconfig
49c47
< PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 10, GenuineIntel
> PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
51c49
< PROCESSOR_REVISION=0f0a
> PROCESSOR_REVISION=0f0b
55,58c53
< QMAKESPEC=/usr/lib/qt3/mkspecs/cygwin-g++
< QTDIR=/usr/lib/qt3
< QTJAVA=C:\Programme\Java\j2re1.4.1_02\lib\ext\QTJava.zip
< REMOTEHOST=eiger
> REMOTEHOST=wi23
62,63c57,58
< SSH_AGENT_PID=4984
< SSH_AUTH_SOCK=/tmp/ssh-E7u8v0YMfk/agent.5000
> SSH_AGENT_PID=620
> SSH_AUTH_SOCK=/tmp/ssh-IcK8fBbuWM/agent.3992
69d63
< TVDUMPFLAGS=8
71c65
< USERDOMAIN=EIGER
> USERDOMAIN=WI23
75d68
< VS80COMNTOOLS=c:\Programme\Microsoft Visual Studio 8\Common7\Tools\
77,78c70,71
< WINDOWID=6.....
< XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
> WINDOWID=6.....
> XKEYSYMDB=/usr/share/X11/XKeysymDB
81c74
< XTERM_VERSION=Cygwin 6.8.99.901(229)
> XTERM_VERSION=Cygwin 6.8.99.903(238)
tyr cygwin 84
Do you see anything which could be responsible for the different behaviour?
Thank you very much for your help in advance.
Siegmar
