[mpich-discuss] Fatal error in MPI_Barrier
Antonio José Gallardo Díaz ajcampa at hotmail.com
Tue Feb 3 04:12:10 CST 2009
When i put the command "mpd &" in the master node, i receive this:
[1] 8198
mpi at wireless:~$ wireless_57956 (mpd_sockpair 226): connect -5 No address associated with hostname
wireless_57956 (mpd_sockpair 233): connect error with -5 No address associated with hostname
..... and continues thinking ....
Date: Tue, 3 Feb 2009 10:49:29 +0100
Subject: Re: [mpich-discuss] Fatal error in MPI_Barrier
In first place thanks for your help.
I have in the archive:
 /etc/mpd.conf:
#! /bin/sh
# This file contains configuration information for mpicc.  This is
# essentially just the variable-initialization part of mpicc.
# Set the default values of all variables.
# Directory locations: Fixed for any MPI implementation.
# Set from the directory arguments to configure (e.g., --prefix=/usr/local)
prefix=/usr/local
exec_prefix=${prefix}
sysconfdir=${prefix}/etc
includedir=${prefix}/include
libdir=${exec_prefix}/lib
# Default settings for compiler, flags, and libraries.
# Determined by a combination of environment variables and tests within
# configure (e.g., determining whehter -lsocket is needee)
CC="gcc"
WRAPPER_CFLAGS=""
WRAPPER_LDFLAGS="  "
MPILIBNAME="mpich"
PMPILIBNAME="pmpich"
MPI_OTHERLIBS="-lpthread      -lrt   "
NEEDSPLIB="no"
# MPIVERSION is the version of the MPICH2 library that mpicc is intended for
MPIVERSION="1.0.8"
archive /etc/mpd.hosts:
master ifhn=192.168.1.1
slave ifhn=192.168.1.2
archive .mpd.conf:
MPD_SECRETWORD=hola
archive .mpd.hosts:
I use the next command for wake up the cluster:
mpdboot --totalnum=2 --ifhn=192.168.1.1 -f .mpd.hosts
and when i try my job use:
mpiexec -recvtimeout 30 -n 2 ./Proyecto/debug/src/proyecto2
Need you anymore? Thanks.
Date: Mon, 2 Feb 2009 17:30:36 -0600
What parameters did you pass to "configure" when you built
MPICH2?
  [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Antonio José
  Gallardo Díaz
Sent: Monday, February 02, 2009 5:29 PM
To:
  in MPI_Barrier
  Only have two nodes.
Node 1--> name: master -->
  hostname: wireless
Node 2--> name: slave----> hostname:
  wireless2
For wake up the cluster i use the command
  "mpdboot".
For example, i can to see how is the two node's
  id. In my job, i use for example MPI_rank(...) and i receive the number of the
  nodes, however if i use a MPI_Send(...) or MPI_Receive(...), mi job exit of
  the application and show me a error.
If i use "mpiexec -l -n 2 hostname", i
  receive:
0 : wireless
1: wireless 2
I don't know that it is
  the answer for your question.
Thanks.
Date: Mon, 2
  Feb 2009 15:52:52 -0600
  MPI_Barrier
  The error message "unable to find the
  process group structure with id <>" is odd. How exactly did you
  configure MPICH2? Were you able to set up an MPD ring on the two nodes
  successfully?
  Rajeev
    Gallardo Díaz
Sent: Monday, February 02, 2009 12:39
    PM
Subject: Re:
    Hello. I Have tested to use the command:
mpiexec
    -recvtimeout 30 -n 2 /home/mpi/mpich2-1.0.8/examples/cpi
and this is the
    result.
Process 0 of 2 is on
    wireless
Process 1 of 2 is on
    wireless2
Fatal error in MPI_Bcast: Other MPI error, error
    stack:
MPI_Bcast(786)............................:
    MPI_Bcast(buf=0x7ffff732586c, count=1, MPI_INT, root=0, MPI_COMM_WORLD)
    failed
MPIR_Bcast(230)...........................:
MPIC_Send(39).............................:
MPIC_Wait(270)............................:
MPIDI_CH3i_Progress_wait(215).............: an error occurred while
    handling an event returned by
    MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Socki_handle_read(637)..............:
    connection failure (set=0,sock=1,errno=104:Connection reset by peer)[cli_0]:
    aborting job:
    stack:
    failed
    an error occurred while handling an event returned by MPFatal error in
    stack:
MPI_Bcast(786)...............................:
    MPI_Bcast(buf=0xbf82bec8, count=1, MPI_INT, root=0, MPI_COMM_WORLD)
    failed
MPIR_Bcast(198)..............................:
MPIC_Recv(81)................................:
MPIC_Wait(270)...............................:
MPIDI_CH3i_Progress_wait(215)................:
    MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(640)...:
MPIDI_CH3_Sockconn_handle_connopen_event(887):
    unable to find the process group structure with id <>[cli_1]: aborting
    job:
    stack:
    failed
    rIDU_Sock_Wait()
    peer)
eturned by
    MPIDU_Sock_Wait()
rank 1 in job
    21  wireless_47695   caused collective abort of all
    ranks
  exit status of rank 1: return code 1
rank 0 in job
    ranks
  exit status of rank 0: return code
    1
The
    mpdcheck said that has a problem with the first ip but it's solved.
I
    tested:
mpdcheck
    -s
    and in the other node
      mpdcheck -c "name" "number"
    -------------->   Well.
mpiexec -n 1 /bin/hostname
    Well.
mpiexec -l -n 4 /bin/hostname
    Well.
I have to say that with all command i have to put the options
    -recvtimeout 30 because but have problems. Without this option, say
    me:
mpiexec_wireless (mpiexec 392): no msg recvd from mpd when
    expecting ack of request
What can i do?? Please help and sorry
    for my poor english.
Date: Mon, 2
    Feb 2009 18:17:39 +0100
    MPI_Barrier
    Well, thanks for your answer.  Really, the name of mi pc is "Wireless"
    and the othes pc "Wireless2", i use in the two pc, the same user "mpi".
I will try the mpdchech utility and then write
    something.
Thank for all.
Un saludo desde España.
Date: Mon, 2
    Feb 2009 10:55:03 -0600
    MPI_Barrier
    Are you really trying to use the wireless network?
    Looks like that's what is getting used.
    You can use the mpdcheck utility to diagnose
    network configuration problems. See Appendix A.2 of the
    installation guide.
    Rajeev
      José Gallardo Díaz
Sent: Monday, February 02, 2009 9:49
      AM
Subject:
      Hello, this error show me when i try my jobs that use
      MPI.
Fatal error in MPI_Barrier: Other MPI error, error
      stack:
MPI_Barrier(406).............................:
      MPI_Barrier(MPI_COMM_WORLD)
      failed
MPIR_Barrier(77).............................:
MPIC_Sendrecv(123)...........................:
      MPIDU_Sock_Wait()
      unable to find the process group structure with id <��oz�>[cli_1]:
      aborting job:
      stack:
      failed
      MPIDU_Sock_Wait()
rank 1
      in job 15  wireless_43226   caused collective abort of all
      ranks
  exit status of rank 1: killed by signal 9
I have
      two PC's with linux (kubuntu 8.10). I make a cluster using this machines.
      When use for example the command "mpiexec -l -n 2 hostname" i can see that
      it's all right, but when i try to send o receive some thing i have the
      same error. I don't know why. Please i need one hand. Thanks for all.
      El doble de diversión: Con
      Windows Live Messenger comparte fotos mientras hablas.
    Con el nuevo Windows Live lo tendrás todo al
    alcance de tu mano
    alcance de tu mano
  Tienes un nuevo Messenger por descubrir. ¡Descárgatelo!
Actualízate, descubre el nuevo Windows Live Messenger.  ¡Descárgatelo ya!
_________________________________________________________________
Llévate Messenger en tu móvil allá donde vayas ¿A qué esperas?
http://serviciosmoviles.es.msn.com/
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090203/ab9de549/attachment-0001.htm>
