[mpich-discuss] make installtest failures
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Tue Dec 15 13:53:12 CST 2009
mpich2's installer's guide has a section on running mpd as root.
You may want to take look first.
A.Chan
----- "Charles Embry" <csembry at ualr.edu> wrote:
> You mean as root? We are going to be running CONODR under root and
> thus mpich2 will have to be run under root? Or am i misunderstanding
> you?
> From: Anthony Chan <chan at mcs.anl.gov>
> Date: Tuesday, December 15, 2009 1:16 am
> Subject: Re: [mpich-discuss] make installtest failures
> To: mpich-discuss at mcs.anl.gov
> > "make installcheck" uses mpich2's mpiexec which is default to use
> > mpd.  So you need to do "mpd &" before "make
> > installcheck".  Also,
> > run installcheck as regular user first.
> > A.Chan
> > > Hello trying to install mpich2 on our machines in our
> > department so we
> > > can use CONDOR to its fullest. I am getting along fine, I
> > think, until
> > > I get to make installcheck.and get some errors just like what
> > I have
> > > listed below on the last eight test. I have included all the
> > output of
> > > the command in the attached file. Should I worry about these
> > before I
> > > continue?
> > > *** Test F77 program with the MPI collective/datatype checking
> > library> ... No.
> > > The failed command is :
> > > /usr/local/bin/mpich2-install/bin/mpiexec -n 4 wrong_reals
> > > /usr/local/bin/mpich2-install/bin/mpdroot: open failed for
> > root's mpd
> > > conf filempiexec_cluster1.bioinformatics.ualr.edu (__init__
> 1208):
> > > forked process failed; status=255
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
