[mpich-discuss] Hydra issues
    Scott Atchley
    atchley at myri.com
    Wed Aug 26 09:51:10 CDT 2009
On Aug 26, 2009, at 10:35 AM, Pavan Balaji wrote:
>> Ok, I was not patient enough. If I let it run, it eventually
>> starts. The actual walltime is nearly the same as when I use
>> proxies, but the stdout is delayed until the application completes.
> Hydra itself does not do any buffering of stdout/stderr as it comes.
> The problem is that hydra never gets the stdout/stderr events till
> the application process flushes stdout/stderr (or libc's internally
> buffering is full). In fact, this is the same problem with mpd as
> well. For example, you can try a simple program which does
> for (5 loops) { printf("foo\n"); sleep(1); }
> ... and you'll notice that the stdout doesn't get printed till the
> end (both with hydra and mpd). Instead, if you change the above test
> to:
> for (5 loops) { printf("foo\n"); fflush(stdout); sleep(1); }
> ... this should show the output as it appears.
> We, obviously, can't expect users to go around adding fflush() in
> their code, so this is not a good solution. Guillaume @ INRIA and I
> had tried some experiments with this, but there wasn't any solution
> that we could use to work around it. Maybe it's time to look into
> this some more.
> -- Pavan
Pavan,
Is there a downside to using:
setbuf (stdout, NULL);
setbuf (stderr, NULL);
Also, why does using persistent proxies allow immediate output?
Scott
