[mpich-discuss] Hydra issues
Pavan Balaji
balaji at mcs.anl.gov
Wed Aug 26 09:35:30 CDT 2009
> Ok, I was not patient enough. If I let it run, it eventually starts. The
> actual walltime is nearly the same as when I use proxies, but the stdout
> is delayed until the application completes.
Hydra itself does not do any buffering of stdout/stderr as it comes. The
problem is that hydra never gets the stdout/stderr events till the
application process flushes stdout/stderr (or libc's internally
buffering is full). In fact, this is the same problem with mpd as well.
For example, you can try a simple program which does
for (5 loops) { printf("foo\n"); sleep(1); }
... and you'll notice that the stdout doesn't get printed till the end
(both with hydra and mpd). Instead, if you change the above test to:
for (5 loops) { printf("foo\n"); fflush(stdout); sleep(1); }
... this should show the output as it appears.
We, obviously, can't expect users to go around adding fflush() in their
code, so this is not a good solution. Guillaume @ INRIA and I had tried
some experiments with this, but there wasn't any solution that we could
use to work around it. Maybe it's time to look into this some more.
-- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
