[mpich-discuss] fmpich2 lib not found with g95
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Aug 18 09:32:06 CDT 2009
 You can specify an alternate directory for installing MPICH2 during the
installation process.
 Did you try putting quotes (") around the include directory ? You can
also try the non-8dot3 directory names (Try "dir /x c:\")?
Jayesh
  _____
Sent: Monday, August 17, 2009 9:15 PM
To: jayesh at mcs.anl.gov
Subject: RE: [mpich-discuss] fmpich2 lib not found with g95
Thanks for your advice. The 32-bit version worked with g95 but I have to
move \lib and \include to the working directory. Looks that MPI is always
installed under program files (x86) and cannot be changed. How can I
directly point to that directory?
g95 -c hello.f90 -Ic:\program files (x86)\MPICH2\include
cannot find the include path (the spaces matter). Is there some way to
have the path correctly?
Thanks.
Heming
  _____
To: heming_ at hotmail.com
CC: mpich-discuss at mcs.anl.gov
Date: Mon, 17 Aug 2009 10:18:52 -0500
 We current don't provide the gcc libs with the 64-bit version of MPICH2.
This is in our list of todo items though. You can follow our progress on
this task using the ticket,
https://trac.mcs.anl.gov/projects/mpich2/ticket/568 .
 The last time I tried I had a tough time getting gcc 4.5.x (version of
gcc that supports 64-bit executables) compile on Cygwin.
 Unfortunately at this time your option would be to try 32-bit version of
MPICH2 (The 32-bit version of MPICH2 should install on your 64-bit
machine, however you will be compiling/running 32-bit executables using
the lib).
Jayesh
  _____
Sent: Monday, August 17, 2009 10:10 AM
Thanks for help.
I did not see that library under \lib. I downloaded the binary
distribution mpich2-1.1.1p1-win-x86-64.msi from MPICH2 web site and
installed from there. Only those libraries are there:
cxx.lib,fmpich2.lib,fmpich2g.lib,mpe.lib,mpi.lib,rlog.lib,irlog2rlog.lib
and TraceInput.lib.
Thanks in advance.
Heming
  _____
Date: Mon, 17 Aug 2009 09:58:03 -0500
 You should use the gnu fortran lib, libfmpich2g.a, provided with MPICH2
(<MPICH2-INSTALL-DIR>/lib/libfmpich2g.a) to link your programs with g77
(or g95).
 Let us know if it works for you.
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Heming Xu
Sent: Monday, August 17, 2009 9:44 AM
Subject: [mpich-discuss] fmpich2 lib not found with g95
I installed the latest g95 and MPICH2 (binary distribution) on Vista and
set path and library path correctly. when only compiling,
g95 -c hello.f90 -Ic:\Progra~1\MPICH2\include
works fine but
g95 -o hello hello.o -l:c:\Progra~1\MPICH2\lib\fmpich2.lib
gives multiple messages saying
undefined reference to '_mpi_init__', '_mpi_send__', etc
It seems the library does not include the subroutines. Other libraries
mpi.lib,etc are the same.
Do I have to configure MPICH2 in window?
Any assistance would be highly appreciated.
Thanks.
Heming
  _____
HotmailR is up to 70% faster. Now good news travels really fast. Try
<http://windowslive.com/online/hotmail?ocid=PID23391::T:WLMTAGL:ON:WL:en-U
S:WM_HYGN_faster:082009> it now.
  _____
Windows Live: Make it easier for your friends to see what you're up to on
Facebook. Find
<http://windowslive.com/Campaign/SocialNetworking?ocid=PID23285::T:WLMTAGL
:ON:WL:en-US:SI_SB_facebook:082009> out more.
  _____
Windows Live: Keep your friends up to date with what you do online. Find
out more.
:ON:WL:en-US:SI_SB_online:082009>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090818/3f6dc85b/attachment-0001.htm>
