[mpich-discuss] MPI application design
    Ronald Paloschi
    ronald at audaces.com.br
    Tue Aug 18 08:34:00 CDT 2009
Thank you so much for your quick answer... I just didnt send the
batcher.c file... :-)
Anyway... I got the idea... You guys are great!
[]s
Ronald
Rusty Lusk escreveu:
> Hi Ronald,
> As it happens, I have just written an MPI application that does *sort
> of* what you have in mind.   It uses a load-balancing library called
> ADLB that was developed for another purpose, which is where the MPI
> part is, but this little application might do what you need.   It
> takes a file of shell commands (for example, instances of your
> CPU-intensive sequential program) and runs them separately but in
> parallel as part of a single MPI job.   I am attaching the README,
> which has instructions and a simple example.
> Regards,
> Rusty Lusk
> On Monday,Aug 17, 2009, at 8:22 AM, ronald at audaces.com.br wrote:
>> Hi all, This is my first message to this mailing list. Im just
>> entering this world of MPI and MPICH seems to be a wonderful
>> implementation from what Ive seen till now. My subject is not really
>> into MPICH itself buf a more general MPI application design. So... I
>> hope you experts at MPI/MPICH can help me. Well... lets go to the
>> problem: In our company, we a have a CPU intesive algorithm that we
>> already run on a multi-process "manually controlled" (not MPI)
>> environment. The core algorithm is a thirdy party library (not
>> parallel) so, we dont have access to the code in order to implement
>> paralellism on the algorithm itself. But we can see it as a candidate
>> for MPI if we look at the problem at an higher level: A set of
>> problems that can be solved concurrently by this algorithm... The
>> paralellismm consists of solving each problem in parallel. Each "run"
>> of the serial algorithm in a process. And of course we get all the
>> message passing mechanism (that is a big problem regarding parallel
>> applications and MPI handles it very well). We plan to use it like
>> this: Every machine on the network will provide its processors to the
>> Cluster (one machine gives 1, others 2, others 4 processors) in every
>> processor we should run one problem at a time. A central processing
>> unit will coordinate (and collect) the results and manage the
>> processes (using MPI). An example: My problem consists of 100
>> problems to be solved and... on my network I have 10 processing unit
>> (processors on slave machines). Lets say we want to run our algorith
>> (an heuristic procedure) for 10 minutes for each problem. Our
>> controller will for each problem: - See if there is a free Processor.
>> - Send the problem to this processor so that it can compute its
>> solution - Recieve back its solution and keep it. - Repeat till the
>> 100 problems are solved. In this case it will take 100 min. to solve
>> all the 100 problems. (10 mins for each 10 parallel workers, if it
>> weren't in parallel it would take 1000 min.) This is the kind of
>> paralellism that we need. I though of a lot of ways to solve it but I
>> would like to hear what do you guys think. At this time of my studies
>> I'm tending to do it this way: - The controlling unit is a server
>> that accepts connections. - For every new process it needs, it
>> launches (mpiexec) a new process to proccess it, passing the
>> connection as a parameter to the executor. - the executor
>> communicates the progress through mpi to the server. - The it goes
>> till the end; What do you guys think. Any help will be appreciated...
>> Im really stuck by my lack of experience on choosing the way to go.
>> Thanks in advance. Ronald
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090818/24f5ff8f/attachment.htm>
