[mpich-discuss] nemesis
    Guillaume Mercier
    mercierg at mcs.anl.gov
    Sun Aug 16 03:17:29 CDT 2009
Hello,
Yes, Nemesis/MX is supposed to be compatible with Open-MX. Could you
sent me your example program so
that I can find out what is the problem?
Thanks.
Guillaume
shenqian at tsinghua.org.cn a écrit :
> Hi,
> I build mpich2-1.1.1 on top of open-mx-1.1.1, and have ch3:nemesis:mx enabled. Nemesis/MX should be compatible with Open-MX, isn't it? I test the examples shipped by mpich2, they work well. But my MPI program always hang on MPI_Barrier(). The output messages are:
> Open-MX: Send request (seqnum 105 sesnum 0) timeout, already sent 1001 times, resetting partner status
> Open-MX: Cleaning partner 00:11:09:5b:7d:16 endpoint 0
> Open-MX: Dropped 1 pending send requests to partner
> It seems like that the requests can not be send to other nodes. If I switch to the traditional TCP/IP stack, use the ch3:nemesis device, the program can run successfully.
> Could anyone tell me how to handle this issue?
> Regards,
> Qian Shen
