[mpich-discuss] Problem with mpi and mcnpx
Arthur Adkins aaa1156 at ufl.edu
Mon Aug 10 08:46:55 CDT 2009
Hey Anthony,
It appeared when I installed mpich2 on the computer it worked alright but when I tried to run mcnpx I received an error.  I think I am still not sure on how to start mpich2 on the head computer along with all of the slave nodes.  Do you know how to do this? Thanks
Arthur
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Anthony Chan
Sent: Saturday, August 08, 2009 12:54 AM
Subject: Re: [mpich-discuss] Problem with mpi and mcnpx
If you get p4 error, that means you are using mpich1.
I thought you were able to use mpich2 ?  What command you
used that got the p4 error ?
A.Chan
----- "ARTHUR AVERY ADKINS" <aaa1156 at ufl.edu> wrote:
> When trying to run a program called mcnpx with mpi I continually
> get a p4 error and then it will not run.  Does anyone know why
> this is and what I can do in order to fix it or try to fix it?
> Arthur
