[mpich-discuss] Problem with mpi and mcnpx
Anthony Chan chan at mcs.anl.gov
Fri Aug 7 23:54:25 CDT 2009
If you get p4 error, that means you are using mpich1.
I thought you were able to use mpich2 ?  What command you
used that got the p4 error ?
A.Chan
----- "ARTHUR AVERY ADKINS" <aaa1156 at ufl.edu> wrote:
> When trying to run a program called mcnpx with mpi I continually
> get a p4 error and then it will not run.  Does anyone know why
> this is and what I can do in order to fix it or try to fix it?
> Arthur
