[mpich-discuss] hydra and PBS
    Bryan Putnam
    bfp at purdue.edu
    Fri Aug  7 19:37:11 CDT 2009
On Wed, 15 Jul 2009, Pavan Balaji wrote:
> Hi Bryan,
> PBS is not supported yet for Hydra (see
> https://trac.mcs.anl.gov/projects/mpich2/ticket/443). However, you should be
> able to use the ssh bootstrap (which is the default), though it might be
> slightly slower than using PBS natively.
>  -- Pavan
Pavan, thanks for the info.
Could you please also tell me if it's possible to set up a master/slave
type job using mpiexec.hydra. That is the equivalent of something like
mpiexec -machinefile $PBS_NODEFILE -np 1 ./master : -np 3 ./slave
I looked at the output of "mpiexec.hydra --help" and am still not sure how
to do that.
Bryan
> On 07/15/2009 08:10 AM, Bryan Putnam wrote:
> > I've built mpich2-1.1 with configure option:
> >  --with-pm=mpd:hydra
> > As before, mpdboot/mpiexec works normally and now mpiexec.hydra also works
> > with ssh, but not with pbs daemons. Is mpiexec.hydra/PBS not supported yet,
> > or am I doing something wrong? I did run "mpiexec.hydra" within a PBS
> > session.
> > Thanks,
> > Bryan
> > 520% mpiexec.hydra -bootstrap ssh -f $PBS_NODEFILE -np 4 ./hellof
> >  node           2: Hello world!
> >  node           3: Hello world!
> >  node           0: Hello world!
> >  node           1: Hello world!
> > 521% mpiexec.hydra -bootstrap pbs -f $PBS_NODEFILE -np 4 ./hellof
> > HYD_BSCI_init (38): unrecognized bootstrap server: pbs
> > HYD_RMKI_init (44): unable to initialize the bootstrap server
> > main (117): unable to initialize RMK
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
