[mpich-discuss] basic datatype for MPI_Offset
Rob Latham
robl at mcs.anl.gov
Mon Apr 27 08:22:08 CDT 2009
On Mon, Apr 27, 2009 at 08:08:13AM -0500, Dave Goodell wrote:
> If you are running in some sort of heterogeneous environment then this
> code might not work correctly if different processes might select
> different types as aliases for MPI_Offset.
Even more options for you!
You can make a type consisting of sizeof(MPI_offset) instances of
MPI_BYTE:
MPI_Type_contiguous(sizeof(MPI_Offset), MPI_BYTE, &offsettype);
And if you are hacking ROMIO, there are preprocessor macros so that
you can use 'ADIO_OFFSET' as the MPI type and the preprocessor will
replace it with a big-enough type.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
