[mpich-discuss] basic datatype for MPI_Offset
Dave Goodell goodell at mcs.anl.gov
Mon Apr 27 08:08:13 CDT 2009
On Apr 26, 2009, at 11:41 PM, Wei-keng Liao wrote:
> What basic MPI datatype one should use in MPI functions
> for variables of MPI_Offset type? For example,
> MPI_Offset offsets[nprocs];
> MPI_Allreduce(MPI_IN_PLACE, offsets, nprocs, MPI_???, MPI_MAX,
> MPI_COMM_WORLD);
> Will there be a new base type, MPI_OFFSET (all capitals)?
I have proposed [1] a modification to the MPI standard for the MPI-2.2
version that will add MPI_AINT and MPI_OFFSET predefined types
corresponding to MPI_Aint/MPI_ADDRESS_KIND and MPI_Offset/
MPI_OFFSET_KIND respectively.  The MPI Forum has not yet voted on this
proposal, but based on straw votes in the past I think that the
chances of it passing and making into the 2.2 standard are pretty
good.  If it does pass, then MPICH2 and many other MPI implementations
will probably have this feature by early Fall of 2009.
In the interim you can use a hack like the following as long as you
are not running in a heterogeneous environment:
--------8<---------
MPI_Datatype offset_type = MPI_DATATYPE_NULL;
if      (sizeof(MPI_Offset) == sizeof(int))  { offset_type = MPI_INT; }
else if (sizeof(MPI_Offset) == sizeof(long)) { offset_type = MPI_LONG; }
else if (sizeof(MPI_Offset) == sizeof(long long)) { offset_type =
MPI_LONG_LONG; }
else { MPI_Abort(MPI_COMM_WORLD, 1); }
MPI_Allreduce(MPI_IN_PLACE, offsets, nprocs, offset_type, MPI_MAX,
MPI_COMM_WORLD);
--------8<---------
If you are running in some sort of heterogeneous environment then this
code might not work correctly if different processes might select
different types as aliases for MPI_Offset.
-Dave
[1] https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/18
