[mpich-discuss] Problem with mpich2 installation
Dave Goodell goodell at mcs.anl.gov
Wed Apr 22 10:32:15 CDT 2009
What do you mean by "was working perfectly before"?  Was it working
with a previous installation of MPICH2 or a different MPI
implementation?  Was it working when you just used one host but not
with multiple hosts?
This looks like you have not yet created root's mpd.conf file.  If you
insist on running mpd as root, you should follow the directions in
section 5.1.6 of the Installer's Guide that I pointed out before.  It
tells you that you need to create root's mpd.conf file in /etc/
mpd.conf instead of $HOME/.mpd.conf.
-Dave
On Apr 22, 2009, at 1:01 AM, Ankush Kaul wrote:
> We are facing another problem,
> whenever we try to run mpirun command (which was working perfectly
> before) we get this error:
> usr/local/bin/mpdroot: open failed for root's mpd conf filempdtrace
> (__init__ 1190): forked process failed; status=255
> is it anything to do with mpich? how can we undo it?
> On Tue, Apr 21, 2009 at 9:12 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> There are two problems here.  The first is that you do not have
> an .mpd.conf file setup.  Doing what mpd tells you to do when you
> run it will fix this.
> The second is that you are trying to run mpd as root.  This is
> possible and supported, but not really recommended unless you know
> what you are doing.  See section 5.1.6 of the MPICH2 Installer's
> Guide [1] for help with running mpd as root.
> -Dave
> [1] http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.0.8-installguide.pdf
> On Apr 21, 2009, at 10:18 AM, Ankush Kaul wrote:
> After installing mpich2 according to the steps given in the README
> file it asks to test using
> mpd &
> mpdtrace
> mpdallexit
> mpd & gives output :
> [2] 21367
> [root at ccomp2 etc]# configuration file /etc/mpd.conf not found
> A file named .mpd.conf file must be present in the user's home
> directory (/etc/mpd.conf if root) with read and write access
> only for the user, and must contain at least a line with:
> MPD_SECRETWORD=<secretword>
> One way to safely create this file is to do the following:
>  cd $HOME
>  touch .mpd.conf
>  chmod 600 .mpd.conf
> and then use an editor to insert a line like
>  MPD_SECRETWORD=mr45-j9z
> into the file.  (Of course use some other secret word than mr45-j9z.)
> and mpdtrace gives error :
> /usr/local/bin/mpdroot: open failed for root's mpd conf filempdtrace
> this is the forst time i am doing a project in linux clustering n
> cant figure out What is the problem here?
