[mpich-discuss] Problem with mpich2 installation
Ankush Kaul
ankush.rkaul at gmail.com
Wed Apr 22 01:01:03 CDT 2009
We are facing another problem,
whenever we try to run mpirun command (which was working perfectly before)
we get this error:
*usr/local/bin/mpdroot: open failed for root's mpd conf filempdtrace
(__init__ 1190): forked process failed; status=255*
is it anything to do with mpich? how can we undo it?
On Tue, Apr 21, 2009 at 9:12 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> There are two problems here. The first is that you do not have an
> .mpd.conf file setup. Doing what mpd tells you to do when you run it will
> fix this.
> The second is that you are trying to run mpd as root. This is possible and
> supported, but not really recommended unless you know what you are doing.
> See section 5.1.6 of the MPICH2 Installer's Guide [1] for help with running
> mpd as root.
> -Dave
> [1]
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.0.8-installguide.pdf
> On Apr 21, 2009, at 10:18 AM, Ankush Kaul wrote:
> After installing mpich2 according to the steps given in the README file it
>> asks to test using
>> mpd &
>> mpdtrace
>> mpdallexit
>> mpd & gives output :
>> [2] 21367
>> [root at ccomp2 etc]# configuration file /etc/mpd.conf not found
>> A file named .mpd.conf file must be present in the user's home
>> directory (/etc/mpd.conf if root) with read and write access
>> only for the user, and must contain at least a line with:
>> MPD_SECRETWORD=<secretword>
>> One way to safely create this file is to do the following:
>> cd $HOME
>> touch .mpd.conf
>> chmod 600 .mpd.conf
>> and then use an editor to insert a line like
>> MPD_SECRETWORD=mr45-j9z
>> into the file. (Of course use some other secret word than mr45-j9z.)
>> and mpdtrace gives error :
>> /usr/local/bin/mpdroot: open failed for root's mpd conf filempdtrace
>> this is the forst time i am doing a project in linux clustering n cant
>> figure out What is the problem here?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090422/60cca6fc/attachment-0001.htm>
