[mpich-discuss] File I/O causing collective abort of all ranks
Brian Harker brian.harker at gmail.com
Tue Sep 23 12:13:51 CDT 2008
Hello list-
I have a problem with process 0 being able to open a file for writing
and subsequently write to it.  The pertinent section of code looks as
follows:
if ( proc_id == 0 ) then
  open( unit = 1, file = "fubar.dat", status="new" )
  do i = 1, ny
    write(1,*) ( array(i,j), i = 1, nx )
  end do
  close(1)
end if
When this part of the code is reached, the program seems to hang for a
long time while trying to open the file, then spits out the following
error message:
rank 0 in job 11  $HOSTNAME_#####  caused collective abort of all ranks
   exit status of rank 0: killed by signal 9
I am confused about this error, because it is seemingly isolated to
this particular write-to-file by process 0.  During execution, my
slave processes write out other files using this exact same syntax.
Has anyone run across this?  I can't seem to find any useful
information on the interweb.  I have run into this problem with both
MPICH2-1.0.6p1 and MPICH2-1.0.7.  I am using the Intel fortran
compiler, ifort 10.1.012.
Thanks in advance for any input!
Cheers,
Brian
"In science, there is only physics; all the rest is stamp-collecting."
 -Ernest Rutherford
