[mpich-discuss] Mpich2: problems with communications
    The Source
    thesourcehim at gmail.com
    Wed Sep 17 12:18:06 CDT 2008
That's stange. I fixed all errors mpdcheck reported (127.0.0.1) problem.
Now mpd listens on proper address. I also configured ssh so both
machines can access each other without password (like mentioned in
installation notes). I can connect two mpd's manually by launching them
on each machine:
on machine 1 - mpd &
on machine 2 - mpd -h <hostname> -p <port>
mpdtrace -l shows both mpd's are running and on the proper addresses.
However automatic init by mpdboot doesn't work. Sais it can't connect to
remote mpd.
All firewalls are disabled on both machines. Selinuxes are also disabled.
ssh and ping work in both directions.
I'm out of ideas.
Except maybe some strange things happening with my network: some
programs like ssh or ping can access virtual machine, and some like
smbclient or rsh say 'no route to host'. That's really weird.
Rajeev Thakur пишет:
> Looks like the two processes are not able to connect to each other. Is
> there a firewall or something in the networking configuration on the
> two machines that may prevent that. You can use the mpdcheck utility
> to diagnose the problem. See Appendix A.2 of the installation guide.
> Rajeev
>     *From:* owner-mpich-discuss at mcs.anl.gov
>     [mailto:owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *The Source
>     *Sent:* Wednesday, September 17, 2008 10:46 AM
>     *To:* mpich-discuss at mcs.anl.gov
>     *Subject:* Re: [mpich-discuss] Mpich2: problems with communications
>     cpi starts and writes the following:
>     Process 0 of 2 is on WARZONE
>     Process 1 of 2 is on F9Virtual64
>     Nothing more. It never exits. I didn't pass any parameters to cpi.
>     Should I?
>     MPI_Bcast(&size, 1, MPI_INT, 0, MPI_COMM_WORLD) returns success, my program then prints that it is about to call next broadcast, but that's it, next broadcast never returns.
>     My second node is virtual Fedora 9 x86_64 (VMWare), running on server node (real Fedora 9 x86_64). Could it be the problem?
>>     Does the cpi example from the examples directory run?
>>     Does this program fail after the very first broadcast, i.e.,
>>>         if(MPI_Bcast(&size, 1, MPI_INT, 0, MPI_COMM_WORLD)!=MPI_SUCCESS)
>>     Rajeev
>>>     -----Original Message-----
>>>     From: owner-mpich-discuss at mcs.anl.gov
>>>     [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of The Source
>>>     Sent: Wednesday, September 17, 2008 7:45 AM
>>>     To: mpich-discuss at mcs.anl.gov
>>>     Subject: [mpich-discuss] Mpich2: problems with communications
>>>     I'm using mpich2 1.0.7. I installed and configured it on 2
>>>     machines, started daemons.
>>>     The problems begin when I launch my program: first MPI_Bcast
>>>     succeeds, but the second one (or any other communication
>>>     function) hangs. Source code is attached.
>>>     Also when I call MPI_Bcast, second machine deamon prints the
>>>     following:
>>>     F9Virtual64_mpdman_1 (run282): invalid msg from lhs;
>>>     expecting ringsize
>>>     got: {}
>>>     Can anyone look at the code and tell me what's wrong?
>>>     #include <mpi.h>
>>>     #include <stdio.h>
>>>     #include <string.h>
>>>     #include <math.h>
>>>     #include <sys/time.h>
>>>     int main(int arg_c, char** arg_v)
>>>         if(arg_c<2)
>>>             printf("Input file not specified\n");
>>>             return 0;
>>>         if(MPI_Init(&arg_c, &arg_v)!=MPI_SUCCESS)
>>>             printf("MPI initialization failed\n");
>>>             return 0;
>>>         int ProcNum, ProcRank;
>>>         MPI_Comm_size(MPI_COMM_WORLD, &ProcNum);
>>>         MPI_Comm_rank(MPI_COMM_WORLD, &ProcRank);
>>>         int size;
>>>         double e;
>>>         double* A;
>>>         double* b;
>>>         double* x, *xprev;
>>>         FILE* f=0;
>>>         if(!ProcRank)
>>>             f=fopen(arg_v[1], "r");
>>>             if(!f)
>>>                 printf("Error opening input file\n");
>>>                 MPI_Finalize();
>>>                 return 0;
>>>             fscanf(f, "%d", &size);
>>>             printf("Enter desired accuracy\n");
>>>             scanf("%lf", &e);
>>>         if(!ProcRank)
>>>             printf("Broadcasting matrix size\n");
>>>             if(!ProcRank)
>>>                 printf("Failed to broadcast matrix size\n");
>>>         if(!ProcRank)
>>>             printf("Broadcasting accuracy\n");
>>>         if(MPI_Bcast(&e, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD)!=MPI_SUCCESS)
>>>             if(!ProcRank)
>>>                 printf("Failed to broadcast accuracy\n");
>>>         A=new double[size*size];
>>>         b=new double[size];
>>>         x=new double[size];
>>>         xprev=new double[size];
>>>         memset(x, 0, size*sizeof(double));
>>>         memset(xprev, 0, size*sizeof(double));
>>>         if(!ProcRank)
>>>             for(int i=0; i<size; i++)
>>>                 for(int j=0; j<size; j++)
>>>                     fscanf(f, "%lf", &(A[i*size+j]));
>>>                 fscanf(f, "%lf", &(b[i]));
>>>             fclose(f);
>>>         if(!ProcRank)
>>>             printf("Waiting all processes to be initialized\n");
>>>         MPI_Barrier(MPI_COMM_WORLD);
>>>         if(!ProcRank)
>>>             printf("Broadcasting matrix\n");
>>>         MPI_Bcast(A, size*size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
>>>         if(!ProcRank)
>>>             printf("Broadcasting b\n");
>>>         MPI_Bcast(b, size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
>>>         double cursum, totalsum;
>>>         int fin, itercount=0;
>>>         if(!ProcRank)
>>>             printf("Starting calculation\n");
>>>         struct timeval tv1, tv2;
>>>         gettimeofday(&tv1, 0);
>>>         do
>>>             MPI_Bcast(xprev, size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
>>>             itercount++;
>>>                 int snum=(size)/ProcNum;
>>>                 cursum=0.0;
>>>                 totalsum=0.0;
>>>                 for(int n=ProcRank*snum;
>>>     n<((ProcRank==ProcNum-1)?(size):((ProcRank+1)*snum)); n++)
>>>                     if(n<=i-1)
>>>                         cursum+=A[i*size+n]*x[n];
>>>                     else
>>>                         cursum+=A[i*size+n]*xprev[n];
>>>                 MPI_Reduce(&cursum, &totalsum, 1, MPI_DOUBLE,
>>>     MPI_SUM, 0, MPI_COMM_WORLD);
>>>                 if(!ProcRank)
>>>                     x[i]=xprev[i]-1.0/A[i*size+i]*(totalsum-b[i]);
>>>             if(!ProcRank)
>>>                 fin=1;
>>>                     if(fabs(x[i]-xprev[i])>e)
>>>                         fin=0;
>>>                 if(!fin)
>>>                     memcpy(xprev, x, size*sizeof(double));
>>>             MPI_Bcast(&fin, 1, MPI_INT, 0, MPI_COMM_WORLD);
>>>         while(!fin);
>>>         gettimeofday(&tv2, 0);
>>>         if(!ProcRank)
>>>             printf("Matrix A:\n");
>>>                     printf("%lf ", A[i*size+j]);
>>>                 printf("\n");
>>>             printf("\n");
>>>             printf("Line b:\n");
>>>                 printf("%lf ", b[i]);
>>>             printf("\n");
>>>             printf("Iteration number: %d\n", itercount);
>>>             printf("Calculation time: %d microseconds\n",
>>>     (tv2.tv_sec-tv1.tv_sec)*1000000+(tv2.tv_usec-tv1.tv_usec));
>>>             printf("Results: \n");
>>>                 printf("x%d=%lf\n", i+1, x[i]);
>>>         delete [] A;
>>>         delete [] b;
>>>         delete [] x;
>>>         delete [] xprev;
>>>         MPI_Finalize();
>>>         return 0;
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080917/ccda7ac3/attachment.htm>
